01-06-2011, 07:24 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Southern California
| MRC Steering links
Hey does anyone have some suggestions for some steering links for the MRC...Just got the new dark soul chassis and wanted to find out if there were better liknks to use than the stock ones...Thanks
01-08-2011, 06:16 AM | #2 |
Newbie Join Date: Dec 2010 Location: Crawfordsville
I bought the same "darksoul" chassis and see the same goofy problem with the steering linkage. They moved the steering servo way over to the left side. This causes it to bind up when turning sharp to the right. There is a black aluminum piece I had left over on my build. It's a squared off rod with threaded holes in each end. Like a tie rod nut or something. Maybe this is to be used in the stock steering linkage? I didn't see where it was to be used... |
01-08-2011, 08:41 AM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
If you don't want to try and make your own, BWD and RCBros make two great steering setups that should work for you. Look around at some of the build threads for ideas.
01-09-2011, 07:53 PM | #4 |
Newbie Join Date: Dec 2010 Location: amarillo
| I got the same set up for my brothers mrc and had the same problam. We just centered the servo over the axle and that worked for us. He is using a 1/10 size servo so no battery up front, but the battery fits on the rear axle like a dream. I hope this helps. John |
01-10-2011, 11:05 PM | #5 |
Rock Stacker Join Date: Sep 2010 Location: los angeles
hey there scteggy! good to see you are getting that mrc comp ready! if you want i can help you out making some delrin links, if not check out bwd |
