Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Snap!
Old 05-09-2011, 04:20 PM   #1
Default Snap!
Hey guys, was out doing some crawling with my MRC when my left front tire got jammed into a tight spot, when I hit the throttle I heard a SNAP and the truck got loose, however now that wheel seems to no longer be engaged. The wheel can spin without any other wheel turning. Nothing seems to be broken just by looking at it, but was curious if maybe something is broken inside the pumpkin. Any help would be greatly appreciated!
rbaron is offline   Reply With Quote
Old 05-09-2011, 04:28 PM   #2
it's more then likely the plastic locker inside the axle, I would get the metal lockers for them
fallin apart is offline   Reply With Quote
Old 05-09-2011, 04:31 PM   #3
here is the metal lockers:
http://www.jpcustomrcs.com/catalog/i...04/6437793.htm
and some other parts to you might want to upgrade
http://www.jpcustomrcs.com/Losi_mini_crawler.html
Old 05-09-2011, 06:30 PM   #4
Take the wheel off and look at the hex pin, that would be where I would start.
Jslick is offline   Reply With Quote
Old 05-10-2011, 07:38 AM   #5
Big Mike's Avatar
You've broken your first...something. Without more info I have no idea what. Axle or locker. It won't be too difficult to figure out, tear it down and see what you find...
Big Mike is offline   Reply With Quote
Old 05-10-2011, 02:16 PM   #6
If you heard a snap I vote hex pin. Otherwise a plastic locker is very very likely.
As said above, metal lockers fix the weak stock lockers.
Hex pin - if you dont have a spare, use either an old body pin (cut off the excess with side cutter pliers), or a drill bit ground/cut down is pretty strong pin material(1.5mm I think should do). I have used an old nail/pin before when desperate.
Gfresh is offline   Reply With Quote
Old 05-10-2011, 05:05 PM   #7
or you could have bad mesh in the ring and pinion and its flexing the axles enough to make the gears jump mesh mine was doing that but some washers and overdrive pinion fixed that
asw27x is offline   Reply With Quote
