06-21-2011, 12:44 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Agoura Hills, CA
| MRC pro roller vs. my hopped up oldie ?
Was thinking about picking up the pro roller since they are blowing them out everywhere right now but had a couple questions. I've already got a slightly hopped up MRC and was wondering if I could/should interchange a couple things. Does the Pro have metal lockers F/R/M ? If not, Im assuming mine will drop right in from my old MRC. Are the CV drive shafts on the pro better than my MIP CVD's I've already got? Will the MIPs fit on the pro if I want to swap? The Pro doesn't have the nice alloy losi beadlocks does it??? I'm assuming they are plastic. Thanks for any info! |
06-21-2011, 01:08 PM | #2 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
The pro does have the lockers. Im pretty sure the driveshafts are the same. Beadlocks are plastic I do believe. I just got my pro roller today. Very nice unit. I need someone to tell me what the CA glue is. |
06-21-2011, 01:10 PM | #3 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
It has metal lockers F/R/M. The Losi cvd's hold up fine in the Pro Rollers but you can swap in the MIP's if needed. Wheels are plastic but are functional beadlocks. For CA glue just use some from the hobby store used to glue wheels and tires. Last edited by cboggs; 06-21-2011 at 01:14 PM. |
06-21-2011, 01:32 PM | #4 |
Thanks for the info. I may swap the MIPs in...I paid a few bucks for those things a while back.
06-21-2011, 02:27 PM | #5 |
Pebble Pounder Join Date: Mar 2011 Location: SLC UT
I had a regular MRC also before getting the pro roller. What you will want to switch over depends on what you have done to your regular MRC already. Pro Chassis is much better so if you are still using the old chassis you will want to switch to the pro. Pro Chassis uses 4 link suspension front and rear which is better than the 3 link that the regular MRC uses. If you haven't done a zero ackerman steering mod to your regular mrc you will want to just take and use the entire axle / knuckles from the Pro roller. The steering improvements are AMAZING over the regular MRC. So again, depending on what you've modded you might just take your electronics and throw them on the new pro roller and you will notice a huge difference in performance. |
06-21-2011, 10:31 PM | #6 | |
06-23-2011, 11:17 PM | #7 |
In the process of swapping some parts off my old MRC tuber and.... what the heck size hex wrench do I need to remove the tiny bolts on the new pro? It is the smaller bolts that hold the links to the chassis. I've tried every hex wrench I have, metric and sae, and none seem to fit? |
06-24-2011, 06:08 AM | #8 | |
06-24-2011, 08:58 AM | #9 |
Yeah that was the one thing I didn't like about the pro roller when I first got it... the tiny hardware.
06-24-2011, 11:43 AM | #10 |
06-24-2011, 11:48 AM | #11 |
06-24-2011, 11:52 AM | #12 |
06-24-2011, 12:41 PM | #13 |
Newbie Join Date: Jun 2010 Location: Montclair
Yea. I hate the .050 heads too so I was thinking to just swap all the screws from my old rtr to the pro. Don't know why losi would do that
06-24-2011, 12:51 PM | #14 |
06-24-2011, 01:03 PM | #15 |
06-24-2011, 01:16 PM | #16 |
Even good wrenches of that size can cause problems. My good .050 tip snapped off in a MIP drive coupler. Now I either try to drill it out or cut it off.
06-25-2011, 09:04 PM | #17 |
anyone recommend a full size servo mount with the 4 link mounting built in? Doesn't look like RCBros has this anymore and I just pulled the servo tray and realized the mounting tabs for the links are built into it. I was hoping to use my old RC bros full size aluminum servo mount to center the servo nicely. I want to run the battery on the links or rear axle. |
06-26-2011, 05:04 AM | #18 | |
06-26-2011, 08:45 AM | #19 | |
Actually, I try to NEVER use the ball end for breaking hardware free or torqueing them. Use a clean ground hex for this. The ball end is only really good for spinning hardware in/out to snug. | |
06-26-2011, 11:29 AM | #20 |
| Thats what I was thinking about doing with the existing front mount, just taking a blade and dremel to it. Using a rear mount will prob be a bit better though, not as thick. Good idea.
