07-01-2011, 07:01 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
| Novak Mongoose Crawler Micro Brushless System 18.5T
just wondering what motor pinion people running with the mongoose system thanks tom |
07-01-2011, 08:05 PM | #2 |
Newbie Join Date: Oct 2006 Location: Cincinnati
Was wondering the same thing, im down to that and the losi brushless set up.
07-01-2011, 08:49 PM | #3 |
my local fellow compers say It comes with a blue 15tooth that worked great with the stock 60t spur and another one of the locals sead that it is best to run a ccbec also if for no other reasen its good to set the right voltage for what ever servo you are using as the speed control may not be at the proper voltage for it.... |
07-01-2011, 10:09 PM | #4 |
Rock Stacker Join Date: Jun 2009 Location: Agoura Hills, CA
I'm running the supplied pinion that came with the mongoose and it works great.
07-02-2011, 01:33 PM | #5 |
Newbie Join Date: May 2011 Location: Santa Cruz
It comes with the perfect pinion for it. My only problem with it is its an aluminum pinion. I would have rather seen a steel one for longevity. I have one and it is a 15 tooth. Hope this helps.
07-02-2011, 02:57 PM | #6 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
This might be the system I go with.
07-04-2011, 07:50 PM | #7 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Stock pinion works great, no need for an external BEC with a Hitec 645mg or 5645mg. If you go with a higher torque servo, put the BEC on.
07-04-2011, 08:28 PM | #8 |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
It depends on how your setup and how you drive. The 15 tooth is a good place to start and works for most people.
