11-16-2011, 07:10 PM | #1 |
Newbie Join Date: May 2009 Location: Phoenix
| Adding weight??? I have had my Losi MRC for a while now. At this time it is still in stock configuration. One of the biggest problems I had right out of the box is the weight. The rig is to light weight. I tried adding some weights on the wheels, and it helped but it still needs more down low to help grip. Any suggestions?? |
11-16-2011, 07:33 PM | #2 |
Newbie Join Date: Oct 2011 Location: Goleta
I moved my battery to the rear axle and a full size servo with wheel weights up front...
11-16-2011, 08:13 PM | #3 |
weight on the front axle, but honestly after wheel weights and low COG elec. mounting I've learned the light weight has a much diffrent driving style than a 2.2 rig, or even a 1.9 scaler. It seams to me that the MRC pro really likes throttle blipping to hop up on things and suuuper slow crawling in other spots on difficult things. |
11-18-2011, 10:23 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
The stock plastic wheels with weights are still way too light. You really need aluminum wheels with weight. My old MRC had Vanquish wheels and I loaded the fronts with slugs and two slugs in the rear. You just can't get that much weight on the stock setup.
11-20-2011, 08:15 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| What's a good weight?
What's everyones opinion on what a good rtr, front wheel, and rear wheel weight is?
11-21-2011, 03:02 AM | #6 |
It will vary based on driving style, terrain and setup, but I would say around 4.5-6oz for each front wheel/tire and 3.5-4.5oz for each back wheel/tire. You can also add weight to the rear 4-link plate or on the servo plate if you can't get enough on your wheels. |
