12-27-2011, 10:37 AM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Lufkin
| Need advice/opinions
Pic in 2nd post now. I started this thread in the scale forum as well but it's gotten slow and I'm kinda in a rush (typical). I'd repost the pic here but I'm at work and can't access my photobucket acct. If y'all would be so kind as to click the link and check out the last pic (post #13) and let me know if it looks retarded. If it makes a difference, I will comp cut it if I decide to keep it. I'm at a standstill till I get the body mounted or leave it alone all together. Thanks. Opinions please Also, what can I use to outboard the shocks on the stock frame? Do I just drill the holes larger to accept the shock ball? Last edited by Rooney7783; 12-27-2011 at 01:36 PM. |
12-27-2011, 01:36 PM | #2 |
| Re: Need advice/opinions
Figured out I could just copy the whole post and get the image link from there (I'm getting old I guess). Anyway, here it is. And please, any opinion, good or bad, is desired. This is as low as I can possibly get it without cutting out the shifters and part of the seat bottoms. Any lower and the servo is gonna start interfering with the grill as well. How does it look? Looks nothing like I had hoped but I'd like some second opinions. I know with a new frame and everything else I could do a better job but I hadn't wanted to go that far. |
12-27-2011, 05:25 PM | #3 |
32 views and no one has an opinion?
12-27-2011, 07:08 PM | #4 |
Newbie Join Date: Nov 2011 Location: Rochester hills
As is I'd say it looks like poop. Cut out everything in the wheel Wells |
12-27-2011, 07:47 PM | #5 |
| Re: Need advice/opinions Thank you for the reply. I had planned on cutting all the wheel well stuff out but was waiting till I got the height right. I got it a tad lower but the bottom of the grill hits the servo. I think that this body may work in the hands of a better fabricator but if I keep at it, it'll end up being a hacked up piece of shit. I haven't given up all hope but I'm damn close.
12-27-2011, 09:35 PM | #6 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
I think it would look sick if you got rid of the stuff in the fenderwell. Shorten the WB a hair and comp cut the rear. Make a scale ish chassis and tuck the trans up under the seats to get it as low as possible. Or sell me the body and I'll do it. |
12-27-2011, 09:43 PM | #7 |
If you sell it I'll take it. Got a front view?
12-27-2011, 09:56 PM | #8 | |
| Re: Need advice/opinions Quote:
I wonder if I shortened the grill if it would look stupid? I can get one but I wouldn't sell the body. Check out ebay, they have these on there all day for $20 ish and they usually have the windshields. That's why I didn't mind cutting up this one since I can get another so cheap. So is the consensus to chop out all the fenderwell stuff? Front and back? The white part in the rear is the inner fenders on the inside (plastic). All that will get painted at some point. Last edited by Rooney7783; 12-27-2011 at 10:01 PM. | |
12-27-2011, 10:11 PM | #9 |
Don't hack the grill. The cool thing about scalers is you can do a chassis mounted servo. Make a custom Delrin or flat steel chassis and mount the servo up under the hood. As for shortening the WB once you make a custom chassis you can make the chassis side link mounts wherever you want so you can use the same links if you want.
12-27-2011, 10:25 PM | #10 |
Cut as much out ofthe rear as you can without getting into the interior. You make have to run droop in the rear tho
12-27-2011, 10:26 PM | #11 | |
12-27-2011, 10:28 PM | #12 | |
The rear will, without a doubt, be comp cut. That was the idea from the get go. The body is metal, the blue stuff. Any white you see is the plastic interior. The inner wheel wells on the rear are far enough in I shouldn't have to cut them, just the blue metal. I really appreciate all this input guys. Y'alls advice is encouraging me to get out of bed and go work on it some more. Edit: I took a couple more pics of tonights trimming. I just bought a star so I can post em at work tomorrow. Thanks again for the help. Last edited by Rooney7783; 12-27-2011 at 11:00 PM. | |
12-28-2011, 08:30 AM | #13 |
As promised here are some pics. You can see where I've started to cut away at the floor. I'm still wracking my brain on the servo/grill issue.
12-28-2011, 08:43 PM | #14 |
Here is the big issue I'm running into. The grill is sitting on the servo as you can see in the first pic (it's not level I know). The easiest solution would be to chop the grill but in the second pic you can see how much I'd have to chop off (the taped portion. I really don't want to move the body or alter the WB as I really like the proportions. What would y'all do?
12-29-2011, 08:52 PM | #15 |
I wouldn't cutthe grill. It will ruin the scale look. Take the servo off the axle. Cut out the front inner fenderwells. Fab a servo mount to mount the servo against the inside of the grill or where the drivers fenderwell was. Will hide the servo and give you clearance.
12-30-2011, 06:01 AM | #16 | |
Would love to....but I have no hobby shop to get supplies from and my tool collection is basically a dremel and some needle nose pliers . I'm thinking of cutting it, I realized if this were my 1:1 I'd have cut it long ago, do what has to be done for function. And I'm thinking that it'll still look like a jeep, just with a short grill | |
12-30-2011, 09:15 PM | #17 | |
Rock Crawler Join Date: May 2011 Location: at your moms
01-01-2012, 10:09 AM | #18 |
| Re: Need advice/opinions |
01-01-2012, 10:47 AM | #19 | |
Rock Crawler Join Date: Jul 2008 Location: River Falls
And you don't need a hobby store to get your materials. Go to your local home improvement store and pick up a small piece of Lexan (around $7) in the window section. You can cut a few sets of chassis rails and mounts out of that. Search some of the scale threads where people built their chassis from scratch and you will get info on link placement / geometry, etc. Here's a pic of the lexan cab I built for my MRC Pro. At 2.5mm thick it is both light and sturdy.. Hope that helps.. Last edited by the_ghetto_rig; 01-01-2012 at 11:37 AM. | |
01-01-2012, 11:25 AM | #20 |
And to be quite honest, I would not use that body, and for a few reasons:
Need advice/opinions - Similar Threads | ||||
Need some onroad advice, opinions, help | canadianbacon | Non Crawler RC's | 1 | 07-20-2011 06:57 AM |
Need a new Cell...advice, opinions.... | jetboat | Chit Chat | 14 | 08-01-2009 09:48 AM |
My proposed total setup... need opinions and advice | phunkodelic | Newbie General | 9 | 06-16-2009 07:07 PM |
Need opinions! | mudrinner4ever | Chit Chat | 5 | 09-26-2006 04:08 PM |
opinions please. | Lucus | Tamiya Clod Buster | 9 | 12-02-2005 03:12 PM |
