01-07-2012, 10:06 PM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: 419 area
| first time trying to make my own chassis
i got bored yesterday so i went and got some steel and started going at it. right now it looks like crap but im still making some more parts for it and if i like how it runs with this setup im going to powdercoat it!! sorry about the bad pics i used my cell phone this is a pic of when i first got it and pics of it now! |
01-08-2012, 09:12 AM | #2 |
Rock Crawler Join Date: Oct 2011 Location: minot
| Re: first time trying to make my own chassis
Steel is gonna make that puppy pretty hebby up top... Aluminium or carbon fiber sheets is the way to go for a plate chassis imo.. I build lots of tubers out of brass and just solder them with a small torch type lighter.. Keep fabbing tho, ur skills will only improve. |
01-08-2012, 07:18 PM | #3 |
i ran it a little today and i did notice it was top heavy so im going to lower height of it and move the battery probably to the rear axle or mount it on the bottom of the radio plate and im going to go aluminum with it. how hard is it to cut carbon fiber sheets and does the tubers you build how hard is it to bend the brass?? and thank you for the encouragement to keep on building!!
01-08-2012, 08:48 PM | #4 |
Carbon fiber sheets u can cut with a dremel wheel or a hacksaw pretty easily. Put blue masking tape on the sheet to draw ur lines and keep the fraying down. Wear eye protection..... carbon splinters are SMALL and more annoying than fiberglass. The brass takes patience and a little know-how/ planning. Its not too hard to bend if the tubing diameter is 3/8 or under.. A spring can help keep the kinks down. |
01-08-2012, 08:51 PM | #5 |
Put ur old chassis back together and start easy with a set of 4-link plates and custom upper links. Those will have a bigger impact on handeling than just a chassis.. Practice those then make a chassis to fit them. Last edited by elsewhere; 01-08-2012 at 08:54 PM. |
01-08-2012, 11:33 PM | #6 |
am i able to buy the 4 link plates or do i have to make them? and is brake line easier or harder than brass to work with? again thanks for the help from ou guys!!
01-09-2012, 07:19 AM | #7 |
Brass u can solder, brakeline is steel so welding or brazing is the way to go with that. Brass is lighter too. |
first time trying to make my own chassis - Similar Threads | ||||
Time to make people feel old... | CmdrZod | Chit Chat | 6 | 12-19-2011 10:18 PM |
trying to make a chassis | theblackmonky | Tools, and Procedures | 17 | 09-13-2009 02:50 PM |
What to make a chassis out of? | BillH | General Scale Talk | 5 | 08-25-2009 01:02 PM |
Make a chassis??? | Lvninprds | Newbie General | 3 | 04-02-2006 12:48 AM |
