05-29-2012, 09:17 AM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Grand Junction
| servo mounting posts
I s there a different option from stock? Seems like every full size I mount the holes are not centered with eachother.
05-29-2012, 04:16 PM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: sa
| Re: servo mounting posts
i have the same thing, in my case since im using the infectious mount i actually split the posts. which was really just for rigidity. But good quesiton, still need some proper ones though, hopefully you find an answer.
05-29-2012, 05:19 PM | #3 |
Yes, only the lower mount holes will line up with a full size servo if you are using the stock servo mounts. I had a bunch of AX-10 servo mounts and used them on a BWD servo plate. |
05-29-2012, 05:53 PM | #4 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
I use either Axial mounts or RcBros mounts. The RcBros mounts have been out of stock for quite a while. The holes may not always line up perfectly with your servo, but if you use servo screws with washer heads, or regular screws with washers, just split the difference and you should be okay.
05-30-2012, 01:35 AM | #5 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
i have axial plate drill for mrc and stock rtr servo mounts only my top holes line up, but i have the stock hardware with washers and no problems.
05-30-2012, 03:52 AM | #6 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
I use the RPM servo mounts withe the Infectious mount. Solid as a rock |
05-30-2012, 07:38 AM | #7 |
Thanks Bill, that's exactly what I was looking for.
05-30-2012, 07:58 AM | #8 |
| Re: servo mounting posts |
05-30-2012, 09:28 AM | #9 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
05-30-2012, 03:30 PM | #10 |
Those look good too. Kinda pricey though. Thanks Everett.
05-30-2012, 06:29 PM | #11 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Sorry Guys, I didn't realize my cart showed out of stock on the servo posts. They are now available: RcBros Hobbies |
05-31-2012, 07:24 AM | #12 |
Damnit. I wanted those too! I guess i'll order them in a couple weeks even though I ordered some other ones.
servo mounting posts - Similar Threads | ||||
Mounting XR10 'Hardline' body - Which posts to use? | DiggyStyle | Paint and Body | 7 | 02-17-2012 12:24 PM |
Servo posts | 8500lbs | Tamiya TLT Crawlers | 10 | 07-28-2007 01:54 AM |
where can i find servo mount posts???? | dieselfuel | Newbie General | 4 | 06-29-2006 10:12 PM |
