09-19-2012, 02:21 PM | #1 |
Pebble Pounder Join Date: Aug 2012 Location: Australia
| Voltage output.
I`ve looked everywhere for the voltage output of the bec on my stock esc and can`t find a thing. Can anyone tell me please? I`m changing my servo to something with more grunt, but I`m trying not to have to buy an external bec. I`m a self confessed tight arse. |
09-19-2012, 02:27 PM | #2 |
RCC Addict Join Date: Jun 2009 Location: Australia
If we have some details as model, make etc someone may be able to help Sent from my GT-I9100T using Tapatalk 2 |
09-19-2012, 02:44 PM | #3 |
| Re: Voltage output. |
09-19-2012, 08:18 PM | #4 |
| Re: Voltage output.
Lol, do ur arse a favor an get a external bec! If not it will help you burn the esc you have up so you can get a upgraded one of those.. they cost more... |
09-19-2012, 10:35 PM | #5 | |
| Re: Voltage output. Quote:
I`m still on the learning curve. | |
09-20-2012, 12:22 PM | #6 |
Pebble Pounder Join Date: Jun 2011 Location: Port Charlotte
| Re: Voltage output.
Could you point me to a good link on installing a bec. Not having one might be causing my stock esc to burn up using a lipo. Thanks
09-20-2012, 01:42 PM | #7 | |
Castle Creations | CC BEC and CC BEC Pro Scholl down to the resources section and you will see the link for a wiring diagram. I`m using the CC bec. Last edited by philg; 09-20-2012 at 01:51 PM. | |
09-20-2012, 03:10 PM | #8 |
| Re: Voltage output.
It's real easy.. there are a couple ways to do it.. easiest way.. wire the red an black to the red an black coming from the battery to ur esc..either at the deans plug or at the esc.. pull the red power wire coming from ur esc to ur rx, make sure to shrink wrap it or electrical tape, then plug ur bec into a spare slot in ur rx, yes the bind plug slot works.. done.. easiest way.... Last edited by winnerone23; 09-20-2012 at 03:22 PM. |
09-20-2012, 03:41 PM | #9 |
| Re: Voltage output.
Thanks guys, this is why I pay my membership fee!!
Voltage output. - Similar Threads | ||||
low output voltage???? | mudn_1 | Electronics | 4 | 11-29-2010 10:52 AM |
CC BEC voltage output | ScaleReady | Newbie General | 4 | 04-20-2010 05:44 PM |
ESC voltage output? | benroe ax10 | Electronics | 3 | 01-16-2009 03:15 PM |
change output voltage? | Georgerm | Electronics | 2 | 07-13-2008 05:49 PM |
Voltage output of the charger | cj4qts | General Crawlers | 4 | 06-13-2006 11:05 PM |
