08-30-2013, 10:50 PM | #1 |
Rock Stacker Join Date: Dec 2008 Location: Milan
| What size pinion gear and what pitch?
I need some help? I am looking for a pinion gear for my Losi MRC. I just purchased the Novak Three eighty brushless combo setup and I am trying to figure out what size pinion gear to use and what pitch is the stock spur gear. Thanks
08-30-2013, 11:04 PM | #2 |
You need the Novak .5 mod pinions for it. You can get a pack with 11t, 12t, &13t pinions in the same pack.. around 12$ on the Bay Last edited by winnerone23; 08-30-2013 at 11:06 PM. |
08-31-2013, 09:49 AM | #3 |
| Re: What size pinion gear and what pitch?
Thanks, do you know what pitch the gears are?
08-31-2013, 12:19 PM | #4 |
Same as stock.. don't know what P they are.
08-31-2013, 02:19 PM | #5 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
Mod .5 is the pitch
08-31-2013, 04:34 PM | #6 |
I went to my lhs and they sold me a Robinson 48 pitch 17 tooth gear. Will it work on my truck?
09-02-2013, 12:05 AM | #7 | |
| Re: What size pinion gear and what pitch? Quote:
It will work, the pitch is very similar. I just compared them and visually its hard to tell the difference. The gears might be a little bit noisier than normal at first but should break in together, you should not have any problems. | |
What size pinion gear and what pitch? - Similar Threads | ||||
pinion and spur gear size | jcolvin | General Crawlers | 1 | 04-25-2012 10:13 AM |
stock pinion pitch size | waffelhauz | Losi Micro-Rock Crawler | 1 | 05-14-2011 08:43 AM |
pinion gear pitch | WKKILLER | General Crawlers | 6 | 08-08-2009 12:31 AM |
Bully pinion gear - what tooth and pitch? | Tomy | RC4WD Bully | 1 | 04-18-2009 10:17 AM |
