04-23-2015, 08:08 PM | #1 |
Rock Stacker Join Date: May 2011 Location: At the bottom and heading to the top
| Mounts for Shocks and links
Hey all, What are you using for shock and link mounts besides the stock ones |
04-25-2015, 10:50 AM | #2 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Mounts for Shocks and links
At the axle? There are only really two options available anymore, and both require other supporting mods. Are you having problems with the stock link/shock tabs? I quit having problems with them as soon as I quit over-torquing the stock M2 hardware... Check out BWD's "Bomb Proof" Delrin shock and link mounts here, which will require M3 rod ends and link hardware, but work with stock c-hubs, knuckles, and lockouts. Be sure to order the appropriate version that matches your lockout style! - Crawler Parts - Losi Mini Rock Crawler - Billet Works Designs And DravTech's "Wraptors" here, which require a full XR/Wraith steering conversion AND M3 rod ends and shock and link hardware. If you're wanting to do the XR steering swap this is probably the route you want to take. He also sells a matching rear lockout to allow the same upgraded link and shock mounts, but with stock MRC Pro rear single piece shafts - https://www.shapeways.com/product/7T...i-rock-crawler |
04-29-2015, 07:21 PM | #3 |
Thanks that's what I was looking for👍👍👍👍
Mounts for Shocks and links - Similar Threads | ||||
axle mounts for the shocks/links | mudd_slinger | RC4WD Bully | 0 | 10-07-2013 09:28 AM |
using stock shocks/mounts with integy links | iluvny081 | Redcat Crawlers | 4 | 02-19-2010 03:02 PM |
tlt links mounts | Magic | Tamiya TLT Crawlers | 2 | 12-08-2004 10:20 PM |
