Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Shock info for mini builds of ALL types...
Old 04-27-2015, 06:17 PM   #1
Default Shock info for mini builds of ALL types...
Just a quick start to something I've wanted to do for some time. This will become a complete "mini only" shock reference thread in time, and will give you all the numbers you need to know when looking for shocks for your next project. Not necessarily just for the crawler guys, I will start adding pics and more info soon on ALL the mini applicable shocks I come across in my meandering. Even a few options that came from some pretty unlikely sources that would fit scale and go-fast builds quite well...
Losi branded billet threaded shocks-
Extended length- 82mm
Compressed length- 50mm
Travel- 32mm
Shock body diameter- 8.95mm
Shaft diameter- 2mm
Mini Late Model billet shocks-
Extended length- --mm
Compressed length- --mm
Travel- --mm
Spring inside diameter- 10mm
Shaft diameter- 2mm
Losi Mini T front billet shocks-
Extended length- 55mm
Compressed length- 40mm
Travel- 15mm
Shaft diameter- 2mm
Losi Mini T rear billet shocks-
Extended length- 60mm
Compressed length- 42mm
Travel- 18mm
Shaft diameter- 2mm
*All measured with NO internal or external limiting of any sort. Not even lower spring seats. 1mm should be added to the compressed length and subtracted from the travel measurements if using stock Losi spring seats. Others will differ.
If you guys have other bolt on options or missing info to fill in my blanks, post it up!
89redranger is offline   Reply With Quote
Shock info for mini builds of ALL types... - Similar Threads
Need good shock info dontbsalty Axial Wraith 1 05-12-2013 03:57 PM
where are the Chaotic Pro mini builds? bikerj08 Losi Mini-Rock Crawler 9 12-05-2011 08:41 PM
JPCustomRCs WK shock mounts info jbrandt HPI Wheely King 4 08-16-2007 06:05 PM
Mini Crusher Info? tombstone Chit Chat 17 05-10-2006 02:27 PM
Shock question.. idea... info... Double J General Crawlers 5 02-25-2006 09:06 AM
