Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Vätte
Old 06-19-2015, 12:36 PM   #1
Default Vätte
Vätte
Vätte - Nordic Champion 2016
Vätte - European Champion 2015
Technical stuff:
Chassis: DravTech SuDu Zero
Axles: DravTech Mini axles
Links: Lower links DravTech TI, uppers DravTech AL/CF
Transmission: Team Losi Mini Crawler
ESC: Tekin B1R
Motor: Extreme 380X heli motor
Servo: Protek 160T
Battery: Turningy Nano-Tech 2S 300mAh 45-90C LiPo
Radios: Sanwa/Airtronics MT-4
Tires: Purpmart 4.25" Mini Voodoos
Rims: DravTech 1.9
Shocks: Axial SCX10 Aluminium (shortened)
Springs: Team Losi Mini-T (Pink in front and Red in the rear)
Drive Shafts: SDI Propeller Shafts (Shortened)
Skins: Krawler Konceptz
Else: Over- and underdrive in axles. CF Motor plate in transmission. Aluminium gears in transmission. RCBros spring cups.
Zarizi Tech is offline   Reply With Quote
Old 06-19-2015, 12:38 PM   #2
Default Re: Vätte
Do it...you know you want to.
89redranger is offline   Reply With Quote
Old 09-07-2015, 07:56 AM   #3
Default Re: Vätte
Needs its dress
Krawler Konceptz is offline   Reply With Quote
Old 09-17-2015, 11:04 AM   #4
DravTech
Dravpnir's Avatar
Default Re: Vätte
A thread with few pictures is a boring thread, so lets fix that a little bit...
My plan was to keep my last pair of the stainless spools for a project, but hey what don't you do for your team drivers
Exceed 1/16 ring gears on the DravTech stainless spools for both the front and rear.
For the front there is a Exceed 1/16 pinion gear on a modified Losi pinion shaft. I have grinded down the flange on the shaft. The Exceed shaft is a little bit bigger than the Losi one so I added a drop of Loctite 648 so it will not have any play.
For the rear there will be a modified Axial gear giving it some underdrive.
The transmission contain the HR aluminum gears. To avoid that the output shafts beats up the pocket in the aluminum gear I have added some Loctite 648 so now those shafts are going nowhere.
The transmission housing also got one of the DravTech CF motor plate prototypes. The function is good, but I am not happy how it lines up with the housing yet. I have to send Samu a proper one when I have them ready
As I hate M2 thread in plastic I had to mount some aluminum inserts in the bottom holes of the transmission housing.
Transmission mounted on the SuDuZero skid.
Just a skid is boring so lets add a chassis around it
Then I had time to assemble the knuckles.
Then time ran out for today, but this is up next
Dravpnir is offline   Reply With Quote
Old 09-17-2015, 11:15 AM   #5
Default Re: Vätte
Your building is always epic to follow! Now when it's my rig, it's even more exciting! Looks fantastic so far! I can't wait to see them axles and skins mounted together. It'll be one hell of a package!
Old 09-17-2015, 12:08 PM   #6
Default Re: Vätte
FIXED IT Your building is always epic to follow! Now when it's my rig, it's even more exciting! Looks fantastic so far! I can't wait to see them axles and skins mounted together. It'll be one COOL of a package!
Old 10-06-2015, 01:32 PM   #7
DravTech
Dravpnir's Avatar
Default Re: Vätte
A little more done. Axles are coming together and next up is shimming the ring and pinion gear so I can start shortening the axles.
The wheels are also assembled to be ready when the tires are done.
Old 10-06-2015, 01:39 PM   #8
Default Re: Vätte
Don't ship it to Samu.. He already has so much nice stuff. You know my address
Verstuurd vanaf mijn D6503 met Tapatalk
douwe is offline   Reply With Quote
Old 10-06-2015, 02:36 PM   #9
E.Y. Designs
Default Re: Vätte
I was just about to post before you posted that asking for updates but I remembered you're busy so I didn't ask... Looking awesome
EverettY is offline   Reply With Quote
Old 10-06-2015, 03:25 PM   #10
Default Re: Vätte
Skins on their way!
Old 10-06-2015, 07:08 PM   #11
Location: somewhere near Los Angeles...or a city looking thingy.
Default Re: Vätte
I'm a little dumb so forgive me for asking. But how exactly did you accomplish this?
OTHGbronco82 is offline   Reply With Quote
Old 10-06-2015, 07:34 PM   #12
E.Y. Designs
Default Re: Vätte
They are M3 threaded on the outside of the inserts and M2 threaded on the inside so you just drill the hole out for self tapping M3 screw and then just screw the inserts into it
Old 10-07-2015, 12:22 AM   #13
DravTech
Dravpnir's Avatar
Default Re: Vätte
It is like EverettY said, but I also add a dab of glue before screwing in the insert to make sure it never come loose.
Old 10-10-2015, 05:48 PM   #14
Default Re: Vätte
Ah, makes sense. Now to find some inserts. I'm sure my local bolt shop will have them, or mcmaster carr.
Old 10-26-2015, 08:00 AM   #15
Default Re: Vätte
I have received the first parts for this project for me!
COOOOOOOOL skins by Krawler Konceptz. And these must needed tires from PURPMART! Thank you guys. Now I'm just crossing my fingers, that Tobias can make the rig complete it time. Cause training is only for the weak!
Old 10-26-2015, 11:58 AM   #16
Default Re: Vätte
Anxious to see this rig finished! Looking great so far.....
Sh0rtBus is offline   Reply With Quote
Old 10-28-2015, 05:58 AM   #17
DravTech
Dravpnir's Avatar
Default Re: Vätte
I am working on it, but really need to step up the pace to get it ready in good time before Nordics. I hope to be able to post some progress next week.
Old 10-28-2015, 07:47 AM   #18
Default Re: Vätte
Hopefully sooner!
Old 10-28-2015, 08:53 AM   #19
DravTech
Dravpnir's Avatar
Default Re: Vätte
Doh!!!
I meant EuroCrawl of course
Old 11-04-2015, 08:39 AM   #20
Default Re: Vätte
Received batteries today!
HK Nano-Tech 300mAh 2S 45-90C
Jeeeez, these are small.
