Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Tranny gears! Help!
Old 09-14-2015, 11:18 AM   #1
Default Tranny gears! Help!
Leaving for family vacation, and shredded my mrc pro trans gear the day before, anybody near lincoln city????
Sent from my SAMSUNG-SM-G870A using Tapatalk
montanahemi is offline   Reply With Quote
Old 09-14-2015, 11:43 AM   #2
CODYBOY's Avatar
Default Re: Tranny gears! Help!
I'm not near Lincoln City, what way are you headed on vacation? I'm about 3 hours northeast of you, and could loan you a tranny.
I'm on HWY 58, 35 miles east of Eugene.
CODYBOY is offline   Reply With Quote
Old 09-14-2015, 11:47 AM   #3
Crap, I wish, I'm headed to montana, thru portland... but you are awesome for giving it a shot, true rc brother! "Thumbsup"
Old 09-14-2015, 11:52 AM   #4
CODYBOY's Avatar
Hey, no problem, we all need to be passing it forward. I,m going to PM you.
Old 09-14-2015, 05:03 PM   #5
CODYBOY's Avatar
OK, package will meet you in Montana. Have a good vacation!!!
Old 10-19-2015, 11:00 AM   #6
CODYBOY's Avatar
Well, it has been a month since I loaned you a new MRC PRO gear box for your crawler. I was thinking you might be back from Montana by now and I am ready to start my MRC build. I would really like to hear from you so we can get it back to me.
(Hope this isn't going to be the one time in 30 years in RC that I get taken).
Old 10-20-2015, 10:32 AM   #7
Hay codyboy! Sorry, been super busy since I've been back, you are amazing partner, I have your trans, and will be shipping asap! Along with a gift for your build....
Old 10-20-2015, 01:43 PM   #8
CODYBOY's Avatar
Hey montanahemi, (I'm a mopar guy, but just had to get rid of my 69 Roadrunner) I knew you wouldn't let me down! Hope you had a good vacation, and fun with your MRC. Gifts are always fun, but no need for that, it's all about passing it on.
Ernie,
Old 10-20-2015, 02:08 PM   #9
Lol hemi is a nickname I got back in the army, I'm a chevy man... haha but I can definitely appreciate a beautiful machine! I'm sorry to hear abt ur mopar, another build coming? I sent out the trans, and the other stuff, I know it's all about paying it forward, but these made all the difference with my MRC (pro). I cut mine, but they are awesome scalers! Enjoy my friend, and give me a shout!
Old 10-20-2015, 02:09 PM   #10
Have you done any hot tub business with Pacific hot tub solutions? Your name is very familiar.....
Old 10-20-2015, 03:11 PM   #11
CODYBOY's Avatar
No sorry to say. But we always use to tell our son that he was wearing our hot tub around in his mouth, as in $3600. for braces!!!!
The roadrunner, after a ten year build I just slowly lost interest. No, my 1-1 build days are over, the fun and funds just aren't there anymore. Guess I'm getting old.
Old 11-24-2015, 12:17 PM   #12
tuner's Avatar
Losi mrc metal center gears.
Losi 1 18 Mini Hard Anodizing Aluminum Center Gear Set Hot Racing MRC1000T | eBay
tuner is offline   Reply With Quote
Old 11-24-2015, 02:26 PM   #13
Make sure to glue the outdrives into place with either Loctite 648 or JB-Weld if buying those HR (^) gears. It doesn't take but a few packs to waller the slots for the outdrives out, and then they fail completely shortly after that.
89redranger is offline   Reply With Quote
Old 11-25-2015, 02:12 PM   #14
Natedog's Avatar
Great idea 89redranger, would be nice if the HR gears were steel instead of aluminum.
Old 11-25-2015, 10:00 PM   #15
Steel would be awesome. Even the aluminum set aren't great. I've had the best luck using the aluminum idler/step gear, the stock brass top shaft gear, and the plastic bottom gear with the steel lockers. The problem with aluminum as gear teeth is that over time it wears and gets beat to death, and still results in a failure. Using the aluminum on the brass and plastic seems to be not only smoother, but longer wearing over time. Besides, the plastic bottom gear is cheap to replace and functions well as a fuse of sorts in the drivetrain.
Old 11-28-2015, 06:55 PM   #16
^^^^ 100% agreement! ^^^^
I set up All of MRC tranny's this way.
I can't think of one failure!
The mini mantis is 3yrs, or so, old and still going strong! (And that tranny came out of the one before it). Lol..
winnerone23 is offline   Reply With Quote
Old 12-24-2015, 01:00 AM   #17
Well, thank you everyone for the advice, I wish I'd checked this sooner! @89redranger, you hit the nail on the head! (You must have already had the issue) the aluminum gears chewed apart in there, bc I didn't glue the shafts in. They wallered out and resulted in yet another fail. 5th time fail.
I got tired of the losi trans, and I had a 1/16 traxxas transmission that I've dreamed of putting into my Mrc pro because I've had an 540 sized castle sidewinder brushless setup behind it, and knew it was a bulletproof trans. But I would have to cut out my pretty carbon fiber side plates to make it fit... after this last failure, and almost throwing the truck at the wall, I decided to tear it apart, and figure out how to do this merv tranny once and for all.
Well, a trip to ace hardware for brass and 13hrs later....
Have a few pics I took in process of the build......
I didn't make any plans, just bent the rails as I thought they should be and continued to solder pieces and dremel holes. Here's the first time I put the axles under it....
Then after a trip downstairs to my rc junkyard of parts for screws, I found a traxxas waterproof rx box, so that had to happen.
After mounting up the trans, I re used the belly plate from mrc pro and mounted it under the skid plate.
Hooked up the lower links, and cut my CF side plates up to make brackets for upper links...
Once that was done, it all came together quickly...
But wait... more problems.
The truck was real chattery when going forward, and no reverse. One peek told all though, due the angle of the mip drivelines the universals were binding up on me, so I made an adapter plate for each shock hoop to make it taller.
Problem solved.
Next step is to tear it all apart and clean it so I can get some paint or plastidip on it...will post more pics of it after completely done, but It was out on its first drive, and after a 2200mah lipo, ran great, and i don't think I need to tweak anything, or adjust...
Old 12-24-2015, 08:41 AM   #18
CODYBOY's Avatar
Good job, way to step out of the box!!!! We need to get together after the new year.
Old 12-24-2015, 03:57 PM   #19
Thanks! Yes, for sure... the sands have moved around out here, and revealed some awesome mudding, and crawling on old lava and mud flows. Let alone some of the trail driving...
Old 12-27-2015, 06:25 PM   #20
Crazy frame looks good.
rude_k9 is offline   Reply With Quote
Tranny gears! Help! - Similar Threads
What tranny gears to use?? mtnbker Axial Wraith 5 02-25-2013 09:23 PM
Tranny gears Crawlerboy31 Axial SCX-10 4 11-04-2012 11:44 AM
How many gears in a tranny is best? Duuuuuuuude General Crawlers 2 11-17-2008 02:37 PM
