02-26-2016, 11:31 AM | #1 |
Rock Stacker Join Date: Feb 2014 Location: Eastpointe
| Rubbin in axle
*Rubbing in the axle* Noticed there was a spot in both F&R axles where the there is some drag. Much worse in the rear. I took apart the axle and then re-greased them. The internals are in great condition and was no signs of debris. Is it possible there is actual drag on the housing? The only way to really remedy it as of now is to not tighten the housing halves all the way. |
Rubbin in axle - Similar Threads | ||||
how do I prevent VP hubs and VP knuckle setup from rubbin on stock Jeep JK wheels | MikeJordan | Axial SCX-10 | 5 | 04-15-2013 09:25 PM |
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
Rubbin' is Racin' | Mad Scientist | Chit Chat | 3 | 10-21-2009 04:12 PM |
