02-19-2019, 12:26 PM | #1 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| What gearing options do we have?
I already bought a 10 tooth pinion but was wondering if there are other options to gear down/up the rock rey? Anything that can be done to the differentials? Ultimately, I am trying to decide on a brushless sensored motor and have narrowed it down too a Puller Pro BL 540 in a 2700 kV or 3500 kV. I am not looking for all out speed, I am more concerned about smooth crawling and low speed performance. Last edited by mass-hole; 02-19-2019 at 12:28 PM. |
02-19-2019, 12:32 PM | #2 |
Quarry Creeper Join Date: Jun 2018 Location: CRG
| Re: What gearing options do we have?
I don't believe so. I just got a Baja Rey that came with a 13 tooth installed and I replaced it with the included 10 tooth until I learn how to control this thing. Looks like only one ring and pinion ratio available.
02-19-2019, 02:13 PM | #3 |
Baja Rey ring/pinion fit, but you'd be better off sticking with the bigger Rock Rey gears and going to a larger motor pinion instead... if higher speed was the goal. The Rock Rey gears are physically larger and have a larger contact patch, as well as lower gearing at the axle, which results in less torque twist than having higher axle gearing (even if both final drive ratios were ultimately the same by way of adjusting the motor pinions to match.) The 'Rey doesn't take anything special for motor pinion gears, just standard Mod1 with 5mm bore (same as most 1/8 buggies.) Remember, the stock esc will happily take 4s too.
02-19-2019, 04:43 PM | #4 | |
| Re: What gearing options do we have? Quote:
*Edit - Yup, the BR's axle ratio is 40/14 while the RR's is 42/12. I'll definitely be getting the RR ring and pinion gears when I can. Last edited by elRayRay; 02-20-2019 at 10:56 AM. | |
What gearing options do we have? - Similar Threads | ||||
XV-01 Gearing Options | fyrstormer | Rally | 0 | 02-01-2016 02:45 PM |
Gearing options | a69baldone | RC4WD Trail Finder 2 | 3 | 03-14-2015 05:52 AM |
gearing options??? | skidtoy | Axial Wraith | 1 | 06-12-2013 07:44 AM |
Gearing options? | undercoveraddict | Kyosho Crawlers | 8 | 01-31-2013 09:03 AM |
Gearing options | rlozer | Axial AX-10 Scorpion | 21 | 12-05-2008 01:12 PM |
