Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Losi Rock Rey
Thread: Mats Losi Rock Rey kit
Old 04-11-2019, 04:16 AM   #1
mat
Default Mats Losi Rock Rey kit
Not going to go through the whole build process, just gonna share some pics and stuff
With funds being a bit tight, I went a bit cheap on the electronics. A 32kg servo from Banggood, a 2600kv Surpass motor of eBay and a half decent Hobbywing 120A esc. I’ve run a handful of 3s packs through it so far and it all seems to be holding up well
I removed the battery door a used a Velcro strap to let me use some 5000mah packs I had from when I had some large quads. My biggest pack sticks out about 10mm and the strap solution works a treat. Also printed up a XT60 adapter.
I’ve installed a few hopups like the Boom racing rear link mounts and front top link mount, Losi trailing arms and a set of really nice panels from javis929 on eBay.
Took a risk on a dirt cheap set of GDS racing shocks, set of 107mm for the front and a set of 127mm for the rear. They’re a Proline clone with 3.5mm shafts and all alloy parts. So far they have performed excellent, not leaked and feel really smooth. The only down side is because every part is alloy the spring perch/slider rub/grinds on the alloy body.
So as a trial I’ve been running the springs upside down and so far haven’t seen any negative side effects. I do have a few set of original Proline shocks and all external parts are interchangeable, so you could use the plastic sliders from the Proline rebuild kits.
Got some footage of the first run, I had a quite a few hard tumbles, some you’ll see on this vid....
I was surprised how much abuse the Losi took. Unfortunately it did end in tears
I snapped a shock shaft from a 6ft vertical nose dive. I really can’t blame the shaft for breaking with all that force behind it.
mat is offline   Reply With Quote
Old 04-11-2019, 04:23 AM   #2
Default Re: Mats Losi Rock Rey kit
Your rig looks awesome
willyg1981 is offline   Reply With Quote
Old 04-11-2019, 04:37 AM   #3
mat
Why thank you sir
Old 04-11-2019, 07:01 AM   #4
That rig is awesome
raydaddy is offline   Reply With Quote
Old 04-11-2019, 10:56 AM   #5
Moderator
JatoTheRipper's Avatar
Great looking truck! I love what you did with the wheels.
Old 04-13-2019, 11:45 AM   #6
mat
@raydaddy @JatoTheRipper Thanks guys
Old 04-22-2019, 03:01 PM   #7
That is a great looking rig, nicely done
iridebikes247 is offline   Reply With Quote
Old 04-24-2019, 12:38 AM   #8
Looks great. What tyres are those? I'm running hyrax but due to the locked rear and grip there's no way it will turn like yours does.
mond is offline   Reply With Quote
Old 04-24-2019, 05:48 AM   #9
mat
Hi mond, the tires are dirt cheap of ebay...
https://www.ebay.co.uk/itm/4PCS-2-2-...frcectupt=true
I wanted something a little bit more scale than the stock tires.
I have just ordered the Losi open rear diff for mine to help with the rear end stepping out under power. I'll add my findings to this thread when its all fitted
Old 04-24-2019, 06:14 AM   #10
That's awesome. Was considering buying the open diff myself but not sure how easy it would be to seal them. Id want to keep enough oil in them to help when crawling.
Old 04-25-2019, 05:56 AM   #11
mat
https://www.horizonhobby.com/open-re...ey-p-los232051
They come with o-ring seals, so shouldn't be a problem. I've use similar diffs in the past, with a heavy weight oil I've never had any issues... fingers crossed
Old 05-03-2019, 04:44 PM   #12
Your truck looks fantastic!
Sent from my iPhone using Tapatalk Pro
Thloftus is offline   Reply With Quote
Old 05-10-2019, 02:53 PM   #13
mat
Thanks dude
I’ve added my open rear diff to the Losi and I love it. It really works for the way I drive. I didn’t get the rear switching ends at all. Will totally suck for crawling though lol
A little slo mo vid of the diff installed.
Also side swiped a juicy rock.... it’ll buff out eh!!
Old 05-10-2019, 06:39 PM   #14
Ouch! But so it goes, Lol!
Old 05-12-2019, 03:57 PM   #15
I picked up some of those panels for my RR. They look so much better than the stock body.
Mats Losi Rock Rey kit - Similar Threads
PRICE REDUCTION Losi 1/10 Rock Rey 4WD Rock Racer Kit. RPP Hobby RPP Hobby 0 06-28-2018 01:58 PM
Losi Rock Rey Kit to Baja Rey "Kit" Conversion Parts List daign Losi Rock Rey 1 06-28-2018 06:11 AM
Losi Rock Rey Kit to Baja Rey "KitConversion Parts List daign Losi Rock Rey 0 06-27-2018 07:49 PM
In Stock - New Losi Rock Rey Kit! RPP Hobby RPP Hobby 0 11-22-2017 04:54 PM
