Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Max Speed Technology CMX
Thread: New to cmx
Old 10-25-2017, 07:32 PM   #1
snapon boy's Avatar
Default New to cmx
Is there any must upgrade parts? Or parts to keep on hand. Is the stock motor any good? Better or worse than the axial 27t silver can?
149 r/c worx/scalerfab/team brood.
snapon boy is offline   Reply With Quote
Old 10-25-2017, 09:15 PM   #2
Zukiiholic's Avatar
Default Re: New to cmx
For the short wheelbase there is metal links and shocks.
https://www.ebay.com/itm/Alu-shocks-...QAAOSwLF1X6-3x
I have those and running a RC4WD 35T motor on a AE-5 ESC.
This is now my Favorite Wheeler.
Zukiiholic is offline   Reply With Quote
Old 10-25-2017, 09:28 PM   #3
snapon boy's Avatar
I have that setup on order hopefully it arrives before Thanksgiving. I currently have the stock esc and motor. Is the esc worth using till I can get a better one?
Old 10-25-2017, 10:27 PM   #4
Zukiiholic's Avatar
I received mine has a kit without Electronics, so I don't know how good the Factory one is.
Run it till it quits then upgrade I always say..
Old 10-30-2017, 02:39 AM   #5
The only must-upgrade part on the crawler is the driveshafts, and maybe the stock gears in the cmx, ive seen a few stripped sets. I have had 0 problems with my links and shocks, they are holding up way better than driveshafts for me
Mst cfx
Axial wraith
Axial yeti
8x venom creeper
Nzmaximus is offline   Reply With Quote
Old 10-30-2017, 02:48 AM   #6
snapon boy's Avatar
What drives shafts are you using now?
Old 10-30-2017, 05:49 AM   #7
I have the CFX and need to upgrade to the metal links. I purchased metal pivot ball because the plastic ones are terrible. If you over tighten or use pliers on the they deform. Super soft plastic. I haven’t done my shaft yet I have been working on some scale stuff. I have a chassis mounted servo bracket I created for the front. It is 3d printed. If interested I can post it on Thingiverse or Shapeways. It has a panhard bracket built in and used your existing parts. I also designed a battery box and esc tray that I’ll post pics of soon. I love this truck. It has been a fun build.
gsgraber92 is offline   Reply With Quote
Old 10-30-2017, 11:11 AM   #8
I joined the Band!
I have 2 MST CFX and one CMX and I like them, one CFX was shortened to fit a Barbie Jeep (its in the 1.9 section) and it’s gotten lots of use and even one comp. it’s only issue has been front driveshafts and one CVD broken, but I’m petty sure most of that was too much steering throw that I have since limited
The other CFX is getting a D90 hard body so no issues yet since it’s only been driven in the house.
The CMX has the Tamiya Bronco body and it’s a good performer, the transmission is really noisy...
spaceman5280 is offline   Reply With Quote
Old 10-30-2017, 08:55 PM   #9
Here is the chassis servo mount I designed. I can make it available if people are interested in it. I can make available on shapeways and Thingiverse. The panhard bar is the top left front link. And the servo was positioned to use the existing steering rod without modification.
Old 10-30-2017, 09:26 PM   #10
snapon boy's Avatar
I would be very interested in one
Old 10-31-2017, 11:31 AM   #11
I joined the Band!
I will take one for each of my 3 mst rigs
Old 11-04-2017, 10:16 PM   #12
snapon boy's Avatar
I picked up the brood insanity 35t motor. Hopefully it isn't too fast for this build.
Old 11-05-2017, 06:31 PM   #13
I joined the Band!
Should be good, my kid has a 45t in his bronco and he runs 2s and I have an 85t and it’s too slow even on 3s. I have a 55t to install this winter
Old 11-06-2017, 08:34 PM   #14
snapon boy's Avatar
I got a set of small flatirons and some 1.9 wagon wheels I hope they are not too big. I also hope they will work well with a light truck
Old 11-07-2017, 03:52 AM   #15
I joined the Band!
What body?
Old 11-07-2017, 06:23 AM   #16
snapon boy's Avatar
Toyota land
Old 11-07-2017, 09:24 AM   #17
I joined the Band!
Toyota land
I had to trim the Bronco wheel openings pretty big to fit 4.20 Flatirons...
Old 11-07-2017, 09:34 AM   #18
snapon boy's Avatar
OK I'll have to see what I can come up with
Old 11-07-2017, 10:14 AM   #19
Moderator
JatoTheRipper's Avatar
Highly against the rules. I got barked at for saying something similar.
Old 11-07-2017, 11:01 AM   #20
Default New to cmx
I certainly did not mean to break any rules. I was trying to be helpful. Where do I find the rules for posting? I don’t want to get myself in trouble.
New to cmx - Similar Threads
CMX Avalanche Zukiiholic Max Speed Technology CMX 6 10-25-2017 09:18 PM
MST CMX TJ take 2 03NCTJ Max Speed Technology CMX 34 07-11-2017 06:52 PM
Slipper for CMX ndecisive Max Speed Technology CMX 4 05-22-2017 05:59 PM
Mst cmx way6317 Max Speed Technology CMX 19 09-04-2016 06:51 AM
CMX axles? ThatGearHead Max Speed Technology CMX 1 04-03-2016 02:54 AM
