03-06-2021, 08:01 PM | #1 |
Pebble Pounder Join Date: Apr 2014 Location: South Jersey
| SSD High Ratio for smt10?
So I'm trying to give my smt10 one last try before I sell it. I'm running a 4000kv onyx system, 2s lipo and a 16t pinion currently with stock tires/wheels. The truck just isnt fast enough to jump or have fun bashing. I was told I can go up 2 teeth more in pinion size but I dont believe that's gonna help? Anyways tonight I found on Google SSD makes a high ratio transmission kit and apparently running stock setup you'll gain roughly 8mph top end? So anyone running it??? Is spending $50 gonna be worth it or is it just wasting money? |
03-06-2021, 08:21 PM | #2 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
| Re: SSD High Ratio for smt10?
2 teeth on the pinion would help. I'd change the pinion before buying the transmission. Just keep an eye on temps. Your best option would be to use 3s, but not sure if your system can run 3s. Something around 3000 to 3500kv on 3s would be ideal, but the smt10 needs a ton of upgrades to make it reliable and fast. Sent from my SM-G970U using Tapatalk |
03-06-2021, 09:06 PM | #3 | |
Quarry Creeper Join Date: Oct 2010 Location: So. Cal
| Re: SSD High Ratio for smt10? Quote:
03-07-2021, 06:00 AM | #4 |
My onyx is 3s ready I guess I can try the largest pinion and see what happens....problem is I have this setup in a different brand monster truck and IT FREAKING RIPS! Thing does standing backflips, insane power/torque/top end. I can launch this truck to the moon Lol Then you drive the smt10 and it's like a old AA powered rc from Kmart |
03-08-2021, 06:44 AM | #5 |
You can obtain a similar ratio of the SSD trans thru swapping your pinion/spur. Going up 2 teeth on the pinion won't get you to the SSD ratio. But going up 4 teeth will get you close. Pinions are much cheaper than transmissions. If you already have internal metal trans gears, then get a couple larger pinions. If you still have plastic trans gears the SSD trans starts to look like a better economical choice.
03-16-2023, 12:39 PM | #6 |
Newbie Join Date: Mar 2023 Location: Flushing
Ive been running the SSD Trans in my smt since Ive had it with 0 issues from it. 3800kv motor and stock gearing in the axles. On 2s it feels kinda toyish but still fun, throw a 3s in it and its an absolute handful. Only problem is getting everything in the drivetrain downline of the trans to hold up to the power and abuse reliably.
SSD High Ratio for smt10? - Similar Threads | ||||
SMT10 and SSD steering rods? | Gazzalene | Mega/Monster Trucks | 0 | 06-10-2020 07:58 AM |
The New SSD-RC High Ratio Wraith Transmission Kit | KRAWLR4life | Axial Wraith | 18 | 08-22-2016 05:14 AM |
