Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Micro Tyres
Old 09-09-2010, 10:58 AM   #1
Default Micro Tyres
Hello
For my scale Gelendewagen I need smaller tyres. I have put on some of the solid tyres sold on eBay which reduced the diameter from appr 48mm to appr 43mm. I need tyres with outer diam of around 35 - 36 mm.
I also wonder if the new Micro Rally/SCT wheels/tyres will fit the Micro crawler, they look to be of a wanted size. Maybe if the stub axle also is replaced. I don't have the dimensions for it therefore this question here. Maybe anybody knows or have any advice ?
KuJo is offline   Reply With Quote
Old 09-09-2010, 12:57 PM   #2
The urathane swampers on ebay are I believe 38mm. They are the smallest ones that guy makes I think, not sure about the micro SCT tires but the micro desert truck tires are 33mm.
MGCrawler is offline   Reply With Quote
Old 09-09-2010, 03:09 PM   #3
i was wanting to try the same thing ,but the sct rims are d shaped .you could probably make them work.
jkurb00 is offline   Reply With Quote
