09-05-2013, 10:31 PM | #1 |
Newbie Join Date: Aug 2010 Location: belleville
| Having issues with my losi mrc trans
]I have split the same gear in two different losi trans/transfer case has anyone else had this issue if so how do I fix it so I stop blowing it up :mad: Sent from my Galaxy Nexus using Tapatalk 2 Last edited by minijoe; 09-06-2013 at 08:42 PM. |
09-30-2013, 08:45 PM | #3 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: Having issues with my losi mrc trans
Never seen that before & I run crazy power through the losi trans...Post it up in the micro crawler section you might have better luck .
10-08-2013, 10:11 PM | #4 |
Newbie Join Date: Oct 2013 Location: indiana
It sounds like its either a tight gear mesh, or else your slipper clutch needs cleaned/loosened. My pinion broke, when I was replacing it I tried using the paper method to set my gear mesh (using a thin receipt).My clutch was set so loose that it wouldn't spit out the paper afterwards.So I folded the paper in half to add clearance between the gears.It runs noticably quieter now with the added clearance, so I'm convinced my Trekker was originally set a little to tight.But it still wouldn't spit out the receipt, so I tightened my clutch a little.I'm new to this, but I know its running cooler and quieter so it must like it lol. |
