12-18-2014, 01:01 PM | #1 |
Pebble Pounder Join Date: Dec 2014 Location: NJ
| Problem with Sumo crawler - front not turning
I just got a brand new Sumo crawler. The problem is that the front wheels are not turning. I get power to them (front and reverse) but no left and right function. The front hub (or whatever it is called) is making constant noise like it is trying to turn but wheels do not move. When I turn the crawler and receiver off for a while and then turn them back on, the wheels work for couple of seconds and then stop. Anything I could check before sending the crawler back? |
12-18-2014, 10:31 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
| Re: Problem with Sumo crawler - front not turning
There is a switch on the transmitter to change the steering modes , maybe you just need to cycle the switch and it will work. Mine has performed flawlessly but there's also the possibility that your servo or other electronics are the problem. Please let us know if you figure it out as it may help someone else troubleshoot a problem later.
12-19-2014, 07:18 AM | #3 |
It is not the switch. The rear wheels work fine but the front ones just make noise when trying to turn. This is regardless of which steering mode the TX is on. I will try to contact Redcat today to see if they can help me out.
12-19-2014, 07:53 AM | #4 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
sounds like the servo is gone. I would try to swap the servos around on the esc(front servo to rear output and vice versa). If the servo stil wont work then its the servo. If the front starts working and the rear does not then its going to be the esc/rc combo.
12-19-2014, 08:12 AM | #5 | |
| Re: Problem with Sumo crawler - front not turning Quote:
12-19-2014, 10:30 AM | #6 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
| Re: Problem with Sumo crawler - front not turning That's exactly what he's talking about. Just swap the two black plugs on the ESC. If it's the servo, it's an easy fix, and also something you would want to replace eventually anyway. I blew both of mine really quick messing around with a losi transmission and Danally stroker! Doing donuts, and drifting on hardwood floors kills them quick! |
12-19-2014, 10:40 AM | #7 |
I swapped the wires and the rear still works but the front one doesn't. I guess it is the servo then. I am going to see if Redcat is going to send me a replacement one. As an upgrade, are there any other plug and play servos that I could buy on my own that are more heavy duty?
12-19-2014, 03:07 PM | #8 |
Update: After contacting Redcat, they are going to send me a replacement servo under warranty at no cost to me. Pretty good customer service. Still would like to know what are other servos I could get as a replacement. Something that requires no to minimal mods to the chassis. Plug and play preferred though. |
12-19-2014, 05:12 PM | #9 |
I think the tower pro mg90 will work but I'm going by my memory here so you should probably check it out before buying.
12-20-2014, 10:49 AM | #10 |
Thanks. I will look into the servo you have mentioned. In the meantime, can I disconnect the failed servo and have some 2wd steering fun or that is going to put stress on the ESC? |
12-21-2014, 10:53 PM | #11 |
It won't hurt anything to run it with just two wheel steering. You already have that option as one of the steering modes on the radio anyway.
12-21-2014, 11:08 PM | #12 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
| Re: Problem with Sumo crawler - front not turning |
12-22-2014, 06:21 AM | #13 |
Problem with Sumo crawler - front not turning - Similar Threads | ||||
Problem with sumo crawler!! | SGT | Newbie General | 3 | 05-26-2014 01:14 PM |
Servo turning problem | rccrawler6911 | Electronics | 0 | 07-17-2012 07:08 AM |
turning problem | boohoo | Losi Micro-Rock Crawler | 7 | 06-21-2010 10:41 PM |
Turning radius problem | StigAre | Tamiya CR-01 | 14 | 04-10-2009 01:08 AM |
Turning problem | musk-rat | Electronics | 0 | 03-19-2005 07:43 AM |
