07-13-2016, 07:39 AM | #1 |
Rock Stacker Join Date: Dec 2013 Location: Shanghai
| 1/24 ifa w50 chassis & front diy set
1/24 IFA W50 DIY CHASSIS & FRONT DIY SET. This is just a personal DIY, will not be availabe on banggood as a product. Only 30 sets available. Feel free to contact sangyue@gmail.com if you want it. Below are the vehicles I want to make... This is what I have now... |
07-13-2016, 07:44 AM | #2 |
| Re: 1/24 ifa w50 chassis & front diy set
Chassis setup pictures...
07-13-2016, 07:46 AM | #3 |
Some reference pictures...
07-26-2016, 10:55 AM | #4 |
Pebble Pounder Join Date: Feb 2015 Location: Cambridge, UK
Many thanks to Sam for letting me buy the first chassis in the UK! Received the package yesterday and have spent the morning putting it all together - nice and simple to put together, (following the above pictures as there are no instructions) but I have built the 1/18th chassis and a few of the Orlandoo F-150's so it's not the first time! Everything is nicely bagged But a little bit of damage through the postal system (nothing that can't be fixed!) The transfer case is direct attached to the gearbox'd motor, unlike the 1/18th chassis And the shocks now have (quite firm) internal springs The resin body is nicely detailed if a little 'wonky' - probably just like the 1:1!! The chassis was easy to put together and is really sturdy The axles have had a little upgrade to the front UJ's as they now resemble larger versions of the 1/35th Orlandoo upgraded metal axles Here's a few comparison shots next to my 1/18th chassis (also bought from Sam) And compared to a Meng 1/24th Toyota that's been built up on a 1/35th Orlandoo plastic chassis and axles And a few on her own (mended the crack too)! Really happy with the beast and will work out the details after holidays! |
07-26-2016, 11:55 AM | #5 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Thought you might be first out of the blocks Jimbo Truck looks great - any idea which way you're going with it? I like the green gritter in Sangyue's first post. I'm sorely tempted but way too many projects going on already...
07-26-2016, 01:08 PM | #6 |
Cheers Sparks - I couldn't pass it up! Thinking along the same lines... Need to get the springs bedded in! (And the steering sorted...) (Electrics fitted) (Paint) |
07-30-2016, 04:28 AM | #7 |
Finished the electrics and servo placement with a couple of shaped brass 'L' beams for the TowerPro MG90S servo, Castle Creations 1/18th Sidewinder Miro and Spektrum SR-410 Rx. Also put my Hot Racing shocks on for a bit more ride height/tune-ability with springs and just waiting on a set of the new RC4WD Scrambler tyres to arrive in the UK... Will make a battery tray above the rear axle (needs some weight for the springs) and should have space for a full interior too - if only I could decide what to do with the load space! |
07-30-2016, 03:07 PM | #8 |
Pebble Pounder Join Date: Feb 2016 Location: Contra Costa
Looks great, Jimbo! Did you use RC4wd micro rod ends on your Hot Racing shocks? Looks good and probably provides a bit more freedom of movement I would assume....
08-01-2016, 01:50 AM | #9 | |
| Re: 1/24 ifa w50 chassis & front diy set Quote:
There's nothing wrong with the stock shocks, except I didn't have any springs to tune them and I already had the HR shocks in my box! | |
08-01-2016, 05:46 AM | #10 |
This chassis has tons of potential for bodies.
09-20-2016, 01:40 PM | #11 |
After a bit of a wait for the RC4WD Scrambler tyres to arrive in the UK, I've finally been able to make a decision on the direction this is going in! Made a rear Styrene battery tray which fits a 3S 500mAh easily and keeps the weight down low Decided that my fleet required a fuel tanker (and been playing around on Spintires too) so made a start on the tank and made it so the whole lot flips up to change the battery. Going to use a couple of magnets to keep it shut on the trail and will put a spare tyre between the cab and tank... lots to be getting on with, but this truck just goes anywhere - the tyres are so sticky and 3S gives it a real kick when required! |
09-20-2016, 01:58 PM | #12 |
Quarry Creeper Join Date: Sep 2009 Location: Las Vegas
Looking really good! I love how beefy those tires are, do they fit on those stock rims?
09-20-2016, 02:18 PM | #13 |
| Re: 1/24 ifa w50 chassis & front diy set |
09-23-2016, 01:02 PM | #14 |
Bit more done over the last few days - made a start on the interior, sorted the magnet for the fuel tank fixing along with a spare wheel carrier and made a Tic Tac store for the trail! |
09-23-2016, 10:39 PM | #15 |
^^Jimbo, kind of a dumb question, but ive only owned worm gear crawlers. Does it keep rolling when you release the throttle or do you have a esc that has auto brake?
09-24-2016, 11:09 AM | #16 | |
The motor on this is geared so would hold itself, but I also use a Castle Creations 1/18th Sidewinder Micro which has a really good drag brake too! | |
09-26-2016, 04:20 AM | #17 |
Fantastic job Jimbo you've outdone yourself mate! It looksgreat on the scramblers and I'm just loving the tictac dispensary Soooo jealous of this build.
09-28-2016, 01:39 PM | #18 |
Cheers Sparks - really enjoying this one! Driver, seats and steering wheel installed. Going to put in lights and a windscreen next... |
09-28-2016, 01:47 PM | #19 |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
Wish I had the money for this kit..... Sent from my 831C using Tapatalk |
10-18-2016, 10:15 AM | #20 |
Not quite got there on the windscreen and still waiting for the LED's to turn up. Did get the headlight lenses installed and a lick of paint on - used a rusty scouring pad to add some patina... Thinking that the fuel tank would look best in (rusty) white rather than blue like the cab - thoughts?! |
1/24 ifa w50 chassis & front diy set - Similar Threads | ||||
1/35 4WD FORD F-150 DIY SET (New Product Preview) | sangyue | Micro Scale Rigs | 193 | 02-04-2017 01:40 PM |
Bully II Front & Rear Width set up | Mudeater67 | RC4WD Bully | 5 | 11-16-2015 02:11 PM |
1/18 CNC Axle DIY Chassis (D90&G55) | sangyue | Micro Scale Rigs | 49 | 11-15-2015 02:39 PM |
DIY crawler for me & my kid | trewq | Large Scale Rigs | 17 | 07-07-2015 02:56 PM |
