02-19-2017, 12:31 PM | #1 |
Newbie Join Date: Sep 2016 Location: A1ArmedToaster
| Ambush tire options
I want something that would do better on dirt/ clay as thats my primary driving surface. The stock tires work fine but I want something different. I was looking at the rc4wd Interco Super Swamper TSL tires but if you have a better suggestion let me know. To get a better idea the orange is the routes I've made, some areas should get grass later |
02-19-2017, 06:29 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
| Re: Ambush tire options
I've been thinking about getting the rok lox cause they are slightly smaller and wider, they will fit my build better. Sent from my SAMSUNG-SM-G891A using Tapatalk |
02-19-2017, 07:22 PM | #3 |
Newbie Join Date: Apr 2016 Location: Somewhere
That's what I used, the Rok Lox. Because for some reason they are actually the exact same tread as the 1:10 Super Swampers which I have on my scx10. |
02-20-2017, 06:22 AM | #4 | |
| Re: Ambush tire options Quote:
Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-20-2017, 08:16 AM | #5 | |
The weight of them is very noticeable. It for sure helps the suspension work and keep the wheels on the ground. | |
02-20-2017, 10:43 AM | #6 | |
1/2oz on the battery tray and 1/4 on the back of the servo Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-20-2017, 10:59 AM | #7 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
Weight in the wheels is going to help the suspension articulate better. I'd grab up some RC4WD tires, and some of Fungi's wheels, then add some weight. I like to use a combo of brass Losi wheel weights, and lead tape. The lead tape is 1/4" wide, and is made for tennis players to weight their rackets. It's easy, and it works.
02-20-2017, 11:20 AM | #8 |
I also have wheel weights on the servo and both bumpers. Adding weight to the wheels is for unsprung weight. It will pull down on the suspension when the tires are trying to lift off the ground. And it adds weight to the lowest point on the truck. That looks like a great solution above with the lead tape. I have never seen that stuff before. |
02-20-2017, 01:28 PM | #9 | |
Ambush tire options - Similar Threads | ||||
Ambush Wheels And Tire Options? | JJRCBuilder | Micro Scale Rigs | 12 | 04-19-2017 04:23 AM |
Ambush Driveshaft Options | aorquiz | Micro Scale Rigs | 17 | 01-19-2017 06:37 PM |
Proline Ambush Tire Removal | four12unner | Micro Scale Rigs | 4 | 12-13-2016 10:48 PM |
Proline Ambush parts available soon & New RC4WD Rock Creeper tire | spoo76 | Micro Scale Rigs | 9 | 11-10-2016 12:10 PM |
Ambush CGR Spare Tire ???? | truckman71 | Axial SCX-10 | 5 | 05-22-2009 04:00 PM |
