03-13-2018, 04:55 PM | #1 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Orlandoo Hunter "Lil Punkin"
Well, four months later, it's done... TIPS FOR BUYING & BUILDING AN ORLANDOO: 1. Don't 2. If you ignore #1 and you're over 50, refer back to #1 3. If you choose to ignore #1 and #2 doesn't apply, buy a lighted magnifier. A good one. 4. Leave Dr Frankenstyle a scathing message on his thread 5. Assemble it in a bathtub with the drain stoppered. You'll only lose 15% of the parts & hardware that way instead of 35% 6. Yes, there actually is such a thing as a 000 Phillips screwdriver. Get a good one 7. Dip the tip of the screwdriver lightly in the provided grease to keep from losing screws you can't see. Fortunately, they give you a LOT of spares 8. When you think you have the electronics mounted low enough, lower them some more 9. Leave the front bumper off until after you install the servo and horn 10. A "drop" of CA glue takes on a whole new meaning when you get to the exterior body accessories. Use a pin head to transport a measure of glue you can't see to the part...it'll probably still be too much All that said, the little suckers crawl over anything you throw at them (on a desktop anyway). I won't be doing micro again...I value my sanity. But it's fun! |
03-13-2018, 05:20 PM | #2 |
| Re: Orlandoo Hunter "Lil Punkin"
I’ve got one in a box from the when they were first released. After doing the f1fiddy I kinda don’t wanna for all the reasons you listed above.
03-13-2018, 06:06 PM | #3 |
| Re: Orlandoo Hunter "Lil Punkin" The Jeep is actually easier than the F150 supposedly. Or at least that's what others have told me. I guess I'll find out as I have a F150 waiting to be built.
03-13-2018, 07:51 PM | #4 | |
Pebble Pounder Join Date: Apr 2013 Location: Cliff side
| Re: Orlandoo Hunter "Lil Punkin" Quote:
Its true, Jeep is easy both build and driving it because i have both of them. F150 is pain in the ass to build because you'll need more work to drill hole and some bearing won't fit into the axle shaft plus screwing the ball links to chassis can be mind boggling..more likely those threaded hole may came loose. Plastic parts on F150 are like plastic soldeir and axle diff gear are made from plastics unlike Jeep. Jeep however was improvement version after F150 and more scale when in comes to base chassis. F150 is hard to crawl in tight corners. But F150 is a must have if you've big fan of 1:35 scale r/c collectors. Photos: | |
03-13-2018, 08:01 PM | #5 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
I LIKE the color. And your list is good advice too .... well, most of it. Yeah, I thought they were being pretty generous with the hardware too, 'til I fed a few screws to the vacuum. I never did find that one link-ball. And yep, I tried using a round toothpick for CA ..... WAY too big of a "drop". Luckily, the thing is so small that most people can't even see the "oops's". Oh, and there's room for scathing messages in my thread. (or nice ones) Last edited by dr frankenstyle; 03-13-2018 at 08:07 PM. Reason: roflmao |
03-13-2018, 08:27 PM | #6 | |
Sent from my SM-G930R4 using Tapatalk | |
03-13-2018, 08:31 PM | #7 |
| Re: Orlandoo Hunter "Lil Punkin" Quote: Sent from my SM-G930R4 using Tapatalk |
03-13-2018, 08:36 PM | #8 | |
I got real careful when I was down to my last link ball...wasn't feeling so cavalier about the abundance of spare parts by then! Sent from my SM-G930R4 using Tapatalk | |
03-20-2018, 07:41 PM | #9 |
Alright, you've had a week now, I've been waitin'. Have you turned it into a Lil Jack-o-Lantern yet? Let's see those lights. |
03-22-2018, 05:25 PM | #10 | |
03-22-2018, 07:43 PM | #11 | |
Yeah, it's like somebody told me , "... just turn on the living room light", huh. | |
03-22-2018, 08:47 PM | #12 | |
Want to hear something funny? Ya know what a 2M tech is? Miniature/Microminiature electronic repair technician. That's what I did in the military. I repaired multilayer circuit cards with traces 1/6 of a human hair. If I had to do that now I'd be cross trained or discharged. I too, my friend, will just turn on the living room light ;) Sent from my SM-G930R4 using Tapatalk | |
03-23-2018, 08:26 AM | #13 | |
A'ight, I'll let you slide, the living rm light does a fine job. | |
03-29-2018, 04:46 PM | #14 |
Pebble Pounder Join Date: Mar 2014 Location: Australia
ive got a few of both and IMO the Jeep is harder to build and takes about twice as long, Example the Ford chassis is only a few pieces (main plate, motor cover and light buckets) where the jeep chassis is heaps ( 2 rails, 4 buckets, 2 end caps, 2 cross brace, battery tray, skid plate and gearbox halfs) and each part as a few screws. sure the holes can be a pain to drill out by hand.... but with a dremel it only takes seconds and u will end up with a far more precision hole |
11-22-2018, 01:56 PM | #15 |
Newbie Join Date: Nov 2018 Location: Spain
Hi guys, very cool looking orlandoos. I'm still waiting to receive mine but will like to paint it with the same orange colour of the first post. Can you please confirm what paint are you using? Is it the tamiya TS-56? Thanks! |
11-22-2018, 02:05 PM | #16 |
Thanks! I used Testors rattle can spray enamel in competition orange (1628T). Sent from my SM-G930R4 using Tapatalk |
11-22-2018, 02:12 PM | #17 |
Thanks for the quick answer 2mtech!! I’m from spain and don’t know if I will be able to purchase that brand as the main one I know (I’m a newby painting cars) is tamiya...will see if I can find it or, if not, get a similar tone from tamiya. Thank you very much! |
11-24-2018, 04:11 AM | #18 |
Pebble Pounder Join Date: Jan 2013 Location: south jersey
Damit.just bought a half built f150.kept telling myself there to small.maybe I'll just save myself the headache and toss in dumpster
11-24-2018, 08:09 AM | #19 |
| Re: Orlandoo Hunter "Lil Punkin" |
11-24-2018, 11:56 AM | #20 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
I might have to give one of these a shot, tiny screws don't bother me.. (Macbook Pro keyboard screws, there's at least 50 of them in each keyboard, lol) |
Orlandoo Hunter "Lil Punkin" - Similar Threads | ||||
Joshie builds a berg "Bounty Hunter Style" | Joshie | EnRoute Berg | 16 | 05-17-2016 12:36 PM |
Arcc "Zombie Hunter" G6 Nov 23rd | ROLANDROCKSHOP | Competitions | 57 | 11-24-2013 09:10 AM |
Spare parts build for my son "Rock Hunter" | CarterFab | 1.9 Scale Rigs | 22 | 04-10-2012 02:30 PM |
