Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Front and rear axle cover recommendation?
Old 03-29-2020, 07:11 AM   #1
Default Front and rear axle cover recommendation?
I would like to buy front and rear axle covers for scx24. Having searched in ebay.com and aliexpress.com, I found two kinds of them.
https://www.ebay.de/itm/F%C3%BCr-axi...r=473145459666
https://www.ebay.de/itm/323931431006
I have seen the latter in many youtube channels, but the former only recently in ebay and aliexpress. The latter weighs 9g each, but I don't know the weight of the former.
Which one would you recommend?
Veteran is offline   Reply With Quote
Old 03-30-2020, 12:14 PM   #2
Default Re: Front and rear axle cover recommendation?
Whatever is cheaper. They are all the same if you ask me.
BIGW0RM is offline   Reply With Quote
Old 03-30-2020, 02:13 PM   #3
Probably you're right! I will get the cheaper one, which wouldn't really matter any ways. Thanks!
Old 03-30-2020, 07:23 PM   #4
Well, one is brass and one is aluminum. If the purpose is for weight gain the aluminum one is useless. I too looked at the generic ones but i’m more interested in adding weight lower to the ground.
ProvidentPathfinder is offline   Reply With Quote
Old 03-31-2020, 01:56 AM   #5
I thought so, too.
I've just got the answer from the seller (which took a while).
Aluminum one: 7.7g
Conclusion: Brass is much better!
Old 04-01-2020, 03:15 AM   #6
I’m shocked the aluminum one even weighs that much.
Tags
axle cover, scx24
Front and rear axle cover recommendation? - Similar Threads
Rear axle diff cover bolts JDM74 Axial SCX10 II 5 10-21-2017 07:13 AM
A cover for the battery in back? plate that will cover the rear bed? davidq19 Axial Wraith 7 01-28-2012 11:24 PM
HTML code is Off
