Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: My SCX 24
Old 05-04-2020, 06:05 PM   #1
Default My SCX 24
Upgrade List
Hot Racing
Aluminum: Skid plate
Link set
Front axel case
Rear axel case
Transmission case
Gear box cover
Rear body mount support
Front adjustable shock tower
Rear adjustable shock tower
Rear axle truss upper link mount
Front axle truss upper link mount
Front bumper mount
Front bumper
Steering links
Steel: Front, Rear & Center skid plate
Brass: Front & Rear steering knuckle
Front & Rear diff covers
Steel drive shafts
0.5M spur gear conversion
Dynamite
ECX barrage 1/24 motor
SaVox
SH-0257 micro servos
Shapeways Adventure Brad servo mount for SaVox SH-0257
RC4WD
Raceline Monster 1.0” Beadlock Wheels
Scrambler offroad 1.0” scale tires
Old Man Emu shocks 1/18th
Crawler Innovations
Lil nova single stage micro foam (soft)
Mil Stone 4 wheel spacer/weight kit
Mod19RC rock sliders
Mod19RC low cg esc tray
Spektrum SRS Receiver
Castle Creations Sidewinder Micro 2 ESC
Self made magnetic front body mount
Added rear steering
PFongemie is offline   Reply With Quote
Old 05-04-2020, 06:41 PM   #2
SRJ
Default Re: My SCX 24
Looking great. My build will almost be identical once all the parts arrive. I haven't looked at the sliders yet. May have to get a set of those as well.
SRJ is offline   Reply With Quote
Old 05-04-2020, 07:20 PM   #3
The sliders are nice. Although I’m probably going to have to mod them once the parts for 4 wheel steering arrive
Old 05-05-2020, 05:51 AM   #4
Let me 3D Print that...
RexRacer19's Avatar
Cool build. One thing though. Those are not my rock sliders that you have pictured.
RexRacer19 is offline   Reply With Quote
Old 05-05-2020, 05:57 AM   #5
Default My SCX 24
My bad. I’ve ordered so much stuff lately I assumed I got them from Shapeways. Is there a way you could do a modified version to accommodate rear steer?
Old 05-05-2020, 06:48 AM   #6
Moderator
JatoTheRipper's Avatar
Great looking Deadbolt! I have one on the way. I'd love to get my hands on those Scrambler tires and some wheels, but no such luck.
Old 05-05-2020, 07:17 AM   #7
The wheels came from EBay and the tires direct from RC4WD. I added my email to their waiting list so I was notified when they came back in stock.
Old 05-05-2020, 10:55 AM   #8
RexRacer19's Avatar
No worries. A modified version of what exactly?
Old 05-05-2020, 10:59 AM   #9
The sliders. I’m thinking with the rear steer the tires will rub the back outer corners. Once I have the parts and install them I’ll be able to give some measurements.
Old 05-07-2020, 08:21 AM   #10
What are your thoughts on the steel drive shaft? Mine feels a bit lose on my rig. it is missing the notch at the connection point with the worm gear and it doesn't fit as snuggly at that point as the factory plastic shaft does. Not sure that it causes a problem. I don't notice a difference when running it.
Orbital is offline   Reply With Quote
Old 05-07-2020, 08:29 AM   #11
So far I’m liking it. Mines also loose on both the worm end and the transmission side. Haven’t noticed any difference then the stock. In my opinion it just looks better.
Old 05-08-2020, 06:10 PM   #12
Just had a quick question about those shocks. I notice when you are set flat that the shock appears to be fully compressed. Is that what is happening? If so, couldn't you put the springs on and just mount the shocks up higher in the screw holes above the ones you have them in? Just curious. Those shocks look sweet, just really wondering how they perform, before I go and order some.
Eroc is offline   Reply With Quote
Old 05-08-2020, 06:15 PM   #13
I could mount them higher and probably will once I figure out softer springs. Where they are now gives me more bumper clearance. The stock springs are way to stiff. But they work great with the droop set up.
Old 05-14-2020, 04:21 PM   #14
Swapped out the servos to SaVox micro.
Replaced wheels with Raceline Monster beadlock.
Replaced steering links with HR aluminum.
Installed HR center skid plate.
Added rear steering.
Old 05-14-2020, 04:32 PM   #15
Natedog's Avatar
Deadbolt looking good! Nice, how's the size of that servo compared to stock? Looks like you used spacers under mounting screws or did it fit right? No brown outs or annoying noise?
Wheels look good too, why did you swap out the white steelies?
Old 05-14-2020, 05:34 PM   #16
The servos are the same size as the emax. I have the SaVox servo mount from shapeways up front and the stock mount in back. There’s a slight buzz from the rear. But the amount of time I use it is minimal.
I mounted the white steelies on my other scx24 with the 67 Chevy body.
Old 05-22-2020, 09:28 AM   #17
Finished installing the Spektrum Firma 40 receiver/esc. It’s a little tight. Had to eliminate he esc tray. I drilled small holes in the bottom of the new esc and drilled new holes in the frame to mount. Added magnets to the top for the body mount. Ran wires best I could without shortening any(future project).
Old 05-22-2020, 03:57 PM   #18
Old micro servo led switch. Super easy. Now my 3rd channel controls my lights.
http://www.instructables.com/id/Conv...-and-off-LEDs/
Old 06-07-2020, 09:59 PM   #19
Natedog's Avatar
Nice Spektrum ESC/RX all in one setup, is the throttle smoother with this setup over stock esc combo? Nice servo switch tutorial link too.
I’ve got s barrage motor NIP, are the pinion gears same pitch, number of teeth?
I counted 12T pinion that comes with Barrage motor.
Old 06-08-2020, 03:43 AM   #20
It’s definitely smoother over stock. But I changed out the esc for a Castle Sidewinder micro 2. Tucked under the battery tray. Which is also smooth. Also a lot lighter and gives me the option to go brushless (when I can find one small enough).
As far as the gears, I’m not sure. When I installed the barrage motor I also installed the HR .5 spur gear conversion.
