03-19-2022, 07:18 PM | #1 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
| Treal OD Gears 2/14T Defect Causes Binding
I recently discovered that some of Treals OD gears are defective and will cause significant binding in the drivetrain. I made a video covering what the defect looks like. If you've had a bind problem after installing OD gears you should look for this defect. Also, if you've had a binding problem that you can't track down, this might be a good place to look because it could be tricky to find. https://youtu.be/Tn0DvvAXEMQ |
03-20-2022, 07:19 AM | #2 | |
Newbie Join Date: Mar 2021 Location: Berkshire County
| Re: Treal OD Gears 2/14T Defect Causes Binding Quote:
Thanks for sharing! Sent from my iPhone using Tapatalk | |
Treal OD Gears 2/14T Defect Causes Binding - Similar Threads | ||||
Treal Vaterra Ascender Steel OD Gears Overdrive Gears 14/23T | Natedog | Vaterra Ascender | 10 | 08-23-2022 03:14 PM |
UGRC Predator Gen 8 gets Treal overdrive gears. | JMHZ2401 | Redcat Crawlers | 0 | 09-11-2020 06:38 PM |
Treal Overdrive gears testing | JMHZ2401 | Redcat Crawlers | 3 | 11-19-2019 08:09 PM |
Treal overdrive gears installed and tested | JMHZ2401 | Redcat Crawlers | 2 | 11-06-2019 06:25 AM |
