Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Scx24 brass knuckles
Old 12-10-2022, 04:11 AM   #1
Default Scx24 brass knuckles
What is the heaviest set of knuckles made for the scx24 that doesn’t reduce steering angle? The hot racing extra heavy ones GREATLY reduce angle fyi
austin-92 is offline   Reply With Quote
Old 12-12-2022, 07:29 PM   #2
Default Re: Scx24 brass knuckles
i have a set of treal ones in one truck, seem good. and a set of powerhobby ones in another, both i dont think changed steering angle for me
skurge is offline   Reply With Quote
Old 12-13-2022, 05:03 AM   #3
I saw that treal offers 2 different weights like hot racing does, afraid to try their heavy ones after how the hot racing ones turned out. Probably over thinking it, just don’t want to make another bad purchase. Thanks for the reply though.
Old 12-13-2022, 07:52 AM   #4
I would probably get Samix since they have the threaded hole machined in them. Bolt on weight hangers for more weight down low. Cut the housing to get as much steering angle as your shafts will allow.
Bray D is offline   Reply With Quote
Scx24 brass knuckles - Similar Threads
brass knuckles on stock scx24 bronco issue kennydoggins Micro Scale Rigs 1 05-23-2022 08:37 AM
SCX24 Brass Diff Cover Question mflanders300 Micro Scale Rigs 5 02-20-2022 11:23 AM
Hot Racing Brass Diff Covers scx24 4est Micro Scale Rigs 13 06-30-2021 12:29 AM
Hot Racing Brass Knuckles and SSD Brass Weights compatibility saddlesore Axial SCX10 II 5 07-15-2017 05:27 PM
