05-05-2023, 08:59 PM | #1 |
Quarry Creeper Join Date: Sep 2021 Location: Buffalo
| this is what the rc4wd tf24 should have been
capable just finished this build, shortened scx24 with the rc4wd tf24 body on it, performs GREAT! https://youtu.be/B_nJcb4a8Eg Last edited by skurge; 05-05-2023 at 09:23 PM. |
05-06-2023, 06:47 AM | #2 |
Quarry Creeper Join Date: Apr 2023 Location: NW Connecticut
| Re: this is what the rc4wd tf24 should have been
It does perform very well . Looks good too . What chassis did you use ?
05-06-2023, 07:48 AM | #3 |
| Re: this is what the rc4wd tf24 should have been |
05-06-2023, 08:30 AM | #4 |
I like the tall truck look too !
05-06-2023, 08:37 AM | #5 |
Are those Injora double barrel shocks ? If so is there any binding ? I am running Power Hobby shocks in an AX24 and I get a little binding .
05-06-2023, 01:39 PM | #6 | |
| Re: this is what the rc4wd tf24 should have been Quote:
i've since went back to stock shocks in the front, without limiters i dont think a double barrel on the front is a good move. to much lift in the front end Last edited by skurge; 05-06-2023 at 01:43 PM. | |
05-06-2023, 01:41 PM | #7 |
| Re: this is what the rc4wd tf24 should have been i'm planning eventually to lower the body just a tiny bit. at first i really wanted it to be mounted really low. but after seeing how much flex i get out of this thing, it seems stupid to do it, i dont want to make it any wider than it already is. as of right now, i dont have any rubbing at all. at full flex there's a tiny bit of clearance. worked perfectly. i think being a taller truck kind of throws people off too, they think its going to tip over, but there is almost no weight in this thing up top. its allll in the axles |
05-06-2023, 02:30 PM | #8 |
I think I just saw a teaser video on You Tube with this truck ? Post a link to your build video when you can . |
05-07-2023, 06:58 PM | #9 | |
there's no build video but here's the first one that truck was in https://youtu.be/B_nJcb4a8Eg | |
05-07-2023, 07:11 PM | #10 |
Maybe I saw a similar truck . Again that truck looks and performs great ! Nice crawling spot too .
05-07-2023, 08:11 PM | #11 |
