07-10-2023, 12:43 PM | #1 |
Newbie Join Date: Mar 2015 Location: The Pines of Carolina
| SCX24 Channel 1
What would cause Channel 1 to be reversed no matter if the transmitter is set to “N” or “R”. Example when I pull the trigger on the transmitter the truck goes into reverse on either setting.
07-10-2023, 12:49 PM | #2 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: SCX24 Channel 1
Channel 1 is the steering channel. Easy way to remember is 1 to turn and 2 to burn. You can flip the motor wires and your problem will be solved. |
07-10-2023, 01:07 PM | #3 |
| Re: SCX24 Channel 1 |
07-10-2023, 01:16 PM | #4 |
| Re: SCX24 Channel 1
You could unsolder them at the motor side and flip then re solder. If thats not a good option for you on the plug from the motor to the esc/rx unit are tabs that you can pry up and remove the pins then flip and push the pins back into the plug.
07-10-2023, 01:33 PM | #5 |
07-10-2023, 01:57 PM | #6 | |
| Re: SCX24 Channel 1 Quote: | |
07-10-2023, 02:03 PM | #7 | |
Newbie Join Date: Jul 2022 Location: Linköping
Might help. Skickat från min SM-G525F via Tapatalk | |
07-12-2023, 12:26 PM | #8 |
Quarry Creeper Join Date: Apr 2023 Location: NW Connecticut
| Re: SCX24 Channel 1
My scx24 V2 was giving me problems like the Truck was possessed . I constantly had to adjust the throttle trim , then one day it was going back and forth and turning by itself . I had the Bronco for a week . Replaced the AA batteries that came with it and the exorcism was complete.
07-13-2023, 05:31 AM | #9 |
Pebble Pounder Join Date: Nov 2021 Location: Finland
| Re: SCX24 Channel 1
Good advice! I read somewhere that some people have had their batteries leaking. That would explain this crazy behavior.
07-13-2023, 06:34 PM | #10 |
| Re: SCX24 Channel 1
I have also seen servo twitch due to low transmitter batteries.
SCX24 Channel 1 - Similar Threads | ||||
Channel allocation on new SCX24 HRZ00015 ESC/Receiver | Lumsch | Micro Scale Rigs | 3 | 01-31-2022 11:56 AM |
Scx24 Channel 3?? | VN1MVL-24 | Micro Scale Rigs | 2 | 10-15-2019 11:40 PM |
