07-12-2013, 02:55 PM | #1 |
Rock Crawler Join Date: Jun 2008 Location: trenton
| kenworth winch truck all wheel drive
hey guys ive been working on this truck for a couple of weeks now, I figure its time to post I started with the basic king kit, parted about 50% out any way , this a little how-too on the all wheel drive chassis. time for the mock -up rails, the black rails are the stock king/globe liner rails. as you can see the stock holes, the blue rails are the prototype , to make the chassis an all wheel drive we have to move some of the holes the rear suspension holes have to be moved all the way down as pictures the front holes have to be moved to the center of the rails as pictured now on the read suspension , sense you move it downward, the center crossmember has to be flip and the nipples need to be cut off heres what the rear should look like |
07-12-2013, 03:07 PM | #2 |
| Re: kenworth winch truck all wheel drive
for the front axle I went with a tlt-1 Tamiya , im also adding a 3rd rear axle , axles will be painted orange . this truck will be crazy colors to make this work using a tlt-1 axle , you need to do a little modding, you have to mount the axle flesh against the leafs using no blocks, the leafs have a bipple on them, so you habe drill a little sink hole . also the tlt- axle holes are not drill all the way through, so you have to drll it out axle is mounted, here the new rails I cut and drilled , and also adde all alum crossmembers the 3rd axle, tag axle , you use the same parts of the rear suspension accept for the leafs springs, here you need mount the plate 4 1/8 inch forward, you also need to drill a hole as pictured next you mount the stock control arms as pictured |
07-12-2013, 03:08 PM | #3 |
sense theres is no leaf, your probably wondering what is keeping it pushed downward, its the shock, the shock it self is plenty of force here the steering servo is mount and hooked up front view using for a front rim you have to use the rear inner rim, ive added some nut and bolts to give a little more detail, but myself wont be using this wheels starting to come to life here, here you can see I using the semi bigrib 3-speed not the f350, I have a rod that replaces the top rod making it a through and through |
07-12-2013, 03:09 PM | #4 |
another view , for pulling power im using an 80 turn motor from rc4wd rear view for the front wheels im using the rear inner bud wheel fom rc4wd, ive put a super single tire on it, and added a couple of spacers to make it wider while im waiting on cab to come in I will get started on the dual winch platform |
07-12-2013, 03:10 PM | #5 |
| Re: kenworth winch truck all wheel drive |
07-12-2013, 03:13 PM | #6 |
next I titled the nose 17mm , replaced new hood sides , mounted the grill backer and cut the back out of the cab , the back of the cab has to extended and the roof has to be raised the back of the cab I use part of the sleeper, it works perfect , ive also lifted the back of the roof 6mm next I cut the rear windows out and dipped the side door windows the k/w has double head light buckets, so I used the stock rear bumper for the buckets |
07-12-2013, 03:14 PM | #7 |
heres the cab prefitted today I started on the winch , im using the Tamiya worm gear set up, it has the option for different gear ratios, I went with 1400:1 ratio, this kit was 12.00usd ive also installed 2x back up lights and 4 running lights ive added the mesh , air lines and trailer hook up here I made a tool box I paint the cage yellow platform is orange |
07-12-2013, 03:16 PM | #8 |
07-12-2013, 03:36 PM | #9 |
Quarry Creeper Join Date: Feb 2013 Location: SW Iowa
Very cool, you do some amazing stuff with these big rigs.
07-13-2013, 12:17 AM | #10 |
Rock Crawler Join Date: Jan 2009 Location: Boise
Looking good man. Sent from my Xoom using Tapatalk 2 |
07-13-2013, 06:42 AM | #11 |
07-13-2013, 06:42 AM | #12 |
07-13-2013, 07:26 AM | #13 |
Pebble Pounder Join Date: Dec 2008 Location: kingsland
nice looking build so far well done to you
07-13-2013, 12:10 PM | #14 |
Newbie Join Date: May 2013 Location: Northwest
07-14-2013, 08:54 AM | #15 |
07-14-2013, 10:05 AM | #16 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Wow, the more I see of your work the more I want to build one. I want some fuel tanks...do you know where I can find some without buying a kit ? I remember seeing a web site some time back, but can't seem to find it now. TIA Joe |
07-16-2013, 10:30 AM | #17 |
07-16-2013, 05:58 PM | #18 |
07-17-2013, 02:14 PM | #19 |
07-17-2013, 02:22 PM | #20 |
great build as usual. What do you use to cut your styrene materials with? Your part edges and fitment always look flawless.
kenworth winch truck all wheel drive - Similar Threads | ||||
Jeepfoot, Midwest 4 Wheel Drive shop truck | thisdougsforu | Axial SCX-10 | 3 | 05-03-2012 07:23 PM |
Kenworth K100 | skl1cent | Non Crawler RC's | 12 | 03-25-2011 09:27 PM |
Kenworth T800 | skl1cent | Non Crawler RC's | 9 | 03-18-2011 09:16 PM |
Kenworth T800 | skl1cent | Non Crawler RC's | 1 | 09-14-2009 02:31 AM |
Kenworth SAR | skl1cent | Non Crawler RC's | 22 | 07-25-2009 08:09 PM |
