Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Boom Racing T815 6x6
Old 01-18-2016, 12:11 PM   #1
Default Boom Racing T815 6x6
I didn't see this posted anywhere and was wondering has anyone built one of these yet? Looks pretty cool with some good features.
BoomRacing T815 6x6
If I wasn't in process on my Beast II and didn't have the P601 on order I would look further into this.
offroadace is offline   Reply With Quote
Old 01-21-2016, 11:22 AM   #2
Default Re: Boom Racing T815 6x6
I like the look of al those metal screws holding the body together. However i dont like the 2+1 axle setup.
WesleyRoy is offline   Reply With Quote
Old 01-27-2016, 02:09 PM   #3
Also i am a bit suspicious about the quality of Boom racing.
Old 01-27-2016, 02:49 PM   #4
No need to be so. Yes, Boomracing is chinese and probably for that reason alone many will think it's garbage or a waste of money.
I have experienced however that Boomracing is really interested in the users of their products and their experiences.
For some vague reason many seem to be believe that how more expensive parts are, the better they will be. Which is not necesarilly true...
With new products they ask for feedback on a regular bases and as far i have heard, they actually do something with that feedback.
MaFoDes is offline   Reply With Quote
Old 01-28-2016, 07:22 AM   #5
The problem i have with Boom Racing is that i dont know when it will be original boom Racing or is it just Integy with a boom Racing label on. I remember Integy had an almost the same looking truck.
But have to admit i like the looks. However how does the 2nd axle connect to the 1nd axle. Looks like one driveshaft splits in 2 seperate shafts.. looks very odd.
Old 01-28-2016, 08:51 AM   #6
Same here.
wings_of_fire is offline   Reply With Quote
Old 01-28-2016, 09:02 AM   #7
I think the motor is up front and one of those shafts goes all the way to the transfer case and then comes back to the axles via the universals.
I find the 2+1 axles look weird too.. They should have just extended it and made an 8x8. And I wish they would have used black screws instead of silver.
norco kid is offline   Reply With Quote
Old 01-28-2016, 09:49 AM   #8
It has 2 transfer cases!
Gula is offline   Reply With Quote
Old 01-28-2016, 09:54 AM   #9
Oke that would make sense more. They have an 8x8 also. ANd an 6x6 with a normal set up 1+2.
Old 01-28-2016, 12:56 PM   #10
It looks weird, i have to admit
Oh well. Those Russians and Chechs are known for crazy builds. But they also made/make trucks that just didn't break down. Known for their durability and making it through the entire Dakar events.
Old 01-28-2016, 02:18 PM   #11
I am kind of digging the 2+1 setup. I have 2 6x6 (standard configuration) and this looks like a cool alternative that opens up for some cool body builds for the cab. I also like the 8x8 configuration.
The quality looks pretty impressive for what is being identified by most as Chinese crap.
I don't mind these off brand products as much as most. The only issue I have is with the generic press-fit link rod-ends. They do not hold up to any force whatsoever and never stay back in once they pop out.
Old 01-30-2016, 11:19 PM   #12
Make your own project! Here's my tonka clodbuster based 8X8, 52 inches long.
https://youtu.be/oLwmM22cJ7s
Rubberducky213 is offline   Reply With Quote
Old 01-31-2016, 09:01 PM   #13
Did anybody else notice the freaky way they made the rear leafspring? It looks like torque twist would destroy the rear spring set within minutes.
The steering looks like it would also be a hell of a mess. They pitched the pinion towards the t case and caused the knuckles to be off, but im sure with some tweaking you could make something of this.
rcjeepbuilder is offline   Reply With Quote
Old 02-01-2016, 06:45 PM   #14
I just cant get past the cheesy looking body. It looks sort of like a man kat... I guess... Swing and a miss!
Prop Shaft is offline   Reply With Quote
Old 05-28-2016, 09:56 PM   #15
snapon boy's Avatar
Rubber duck
That thing is wicked cool
149 r/c worx team driver
snapon boy is offline   Reply With Quote
Boom Racing T815 6x6 - Similar Threads
Boom racing G2rebel Vaterra Twin Hammers 16 01-15-2016 03:10 PM
Boom racing jdsusername Axial RR10 Bomber 26 01-05-2016 11:08 AM
Boom Racing Vengeance General Crawlers 45 11-26-2015 04:22 AM
Jim's Tatra T815-7 6x6 Fungi Losi Micro-Rock Crawler 7 04-01-2015 01:34 PM
