05-25-2016, 02:29 PM | #1 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| My foray into the multi-axle world, via the infamous HG P601
I've always thought that a 6x6 or an 8x8 would be fun to have on my roster, but with my limited experience in the scaling/crawling world it was a bit daunting to consider building one withou ever having been up close and personal with one. Along comes the HengGuan P610, cheap like borscht. For the price (under $200CAD to my door) it seemed like it might be worth giving one a try. This'll also be a fun truck to let the neighborhood kids play with so I don't have to worry about them wrecking my nice stuff... The intention (as of now, we'll see how this changes...) is to leave this thing mostly stock and not invest a huge amount of money into it. It is what it is and that's cheap off shore rc truck and I can't lose sight of that. I really like the body. But the pre-painted silver is awful. Right out of the box there's a problem with it. I'm not certain if it's because of the Tx or the ESC (Rx is integrated into the ESC) but the servo doesn't work. Not a big deal, the vendor is sending me new Tx and ESC to fix it. For now, it's running on old XL5 I had laying around and I'm using my Turnigy GTX3 (same as the Flsky gt3b/c) since I have spare Rx's already. The 2 major drawbacks to this rig I see right away are the shocks and the frame. The shocks are horrible, undamped and the caps don't seal so you can't even add oil to damp them. The frame is plastic and has an insane amount of twist. I do like their axle design, it uses a pass through pinion shaft so multi axle set-up is easy and there's a brake included on the terminal end so it bumps up the scale appearance just that little bit... Now on to the pics With this truck in the stable, my old storage solution wasn't up to par. Conveniently someone was getting rid of this shelf - needs some paint to gussy it up but it'll do for now. Last edited by QuesoDelDiablo; 05-25-2016 at 02:34 PM. |
06-14-2016, 09:33 AM | #2 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| Re: My foray into the multi-axle world, via the infamous HG P601
An a good old WK on the shelf
09-14-2016, 10:00 AM | #3 |
Crappy update post ahead because I forgot to grab some pics. Over the last couple weeks I have made a couple of upgrades on the "Ridgeback". First, she got named. My wife decided that "Ridgeback" is her name - she came up with it trying to identify it, while only remembering the model type of my Sawback. I'll happily accept her naming of it just that she's involved a little bit. Next, I found a local guy selling a set of 6 SCX shocks so I grabbed those and put them in. The SCX shocks were about 10mm shorter then the stockers. By using a lower mounting point on the shock hoop (about 20mm down), I was able to offset the loss in shock length and gain a chassis lift of about 10mm which this truck can definitely use to increase approach/departure angles. I also upgraded the frame rails to the metal ones. This makes a huge difference! It added about 10ozs to the truck and got rid of the wet noodle floppiness it had. Suspension works better, steering is crisper too. Upcoming changes/plans: Swap all the electronics - I'm going to put in an AE5 (so I can run 3Sfor more wheel speed), Rx for my good radio gear and a better servo (probably my spare Hitec645MG). Motor will stay with stock unit. Improve the steering - I have a set of SCX knuckles & C Hubs. I'll see if these fit and if they can provide some increased steering throw. Also needs some better steering links. Servo winches, X2. I've got some cheap-o servos that I've converted into winches. Gonna need to mount one front and one rear so this guy can be the official recovery vehicle.. Possibly a cheap BEC to run the steering servo and winches. I've got a Traxxas TQ sound system I might see if jerry-rig into this set-up as well.. The body has a ton of spots for lights so one of these days I'll wire up LED's all over the place. But I hate soldering LED's so that's low on the list... Last edited by QuesoDelDiablo; 09-14-2016 at 10:04 AM. |
09-15-2016, 11:44 AM | #4 |
RCC Addict Join Date: Aug 2013 Location: Missoula
The real ones are nice too I'm really tempted to pick one of the affordable ones up. |
09-15-2016, 01:33 PM | #5 |
For the $175 or so I've got into it, it's quickly turning into one of my favourite rigs..
09-15-2016, 01:35 PM | #6 |
| Re: My foray into the multi-axle world, via the infamous HG P601 |
09-15-2016, 08:04 PM | #7 | |
I joined the Band! Join Date: Mar 2009 Location: Right Here
| Re: My foray into the multi-axle world, via the infamous HG P601 Quote:
Sent from my SM-G900V using Tapatalk | |
09-16-2016, 08:27 AM | #8 | |
Cool, good to know they do fit. But I think you're right about the steering. I was looking closer last night and determined the steering is actually being limited by the stock dog bones bottoming out on the cups. I'll see if I can think any way to improve it some more because I would like some more steering angle - the turn radius is pretty rough for a 6x6 bad enough already... | |
09-16-2016, 09:16 AM | #9 | |
The chub had a boss for a steering stop* but no screw so the plastic links were flexing and allowing the knuckle to turn far enough for the dog bone to push out of the cup and the force would peel the chub off. I finally installed stop screws and the problem was solved. Sent from my SM-G900V using Tapatalk | |
09-16-2016, 10:11 AM | #10 |
When you swapped AX10 gear onto your rig, did you swap the axle shafts too? I find myself wondering if I can run SCX CVD's to get more steering angle.. I might just have to buy a set and try it out.. |
09-16-2016, 10:20 AM | #11 | |
I also just ordered a second set of HG axles for a short wheelbase project cuz the high input will help with driveshaft angles, but the track is a little wide so I'm gonna look into narrowing and I would like to find a universal joint that will fit for better turning radius. Sent from my SM-G900V using Tapatalk | |
09-16-2016, 11:12 AM | #12 |
Glad to find there's somebody else out there working on one of these!
My foray into the multi-axle world, via the infamous HG P601 - Similar Threads | ||||
Multi axle rigs | thurayt | South Carolina | 6 | 02-15-2015 05:52 PM |
New To Multi Axle Rigs | Jakethesnake-rs10 | Multi Axle Rigs | 11 | 11-13-2013 07:10 PM |
multi axle section | scale4x4 | Comments, Suggestions, and Help | 74 | 06-29-2013 12:05 PM |
First foray into FOFF. | lilredmachine | Formula Offroad | 0 | 12-07-2011 01:25 PM |
