Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: TRX-4 6x6
Old 08-05-2019, 04:26 AM   #1
Default TRX-4 6x6
So last year I bought the TRX-4, ran it in one TTC this year and won another TRX-4 kit... I love having more than one axle but making the TRX-4 run 3 axles was a bit more of a challenge...
Past 4 weeks I was on bed rest from surgery, I won the kit 3 days before I went in. Once I was able to sit up and move a little bit I started building.
I didn't take many pics because I wasn't sure if it would actually work, I couldn't find anything on a 6x6 using TRX-4 guts.
I've made 6x6 and 8x8 with Axial but they are simple.
I also just recently got a 3d printer, I was going to make another MAN-KAT 1 but I made the 8x8 outta wood so I figured I would try a different body for this one. I went with a ZIL 131, mostly because I just liked the styling
I found if you extend the shaft they spin the same way, so I have 2 outputs for the rear and a carrier bearing up top
This one just shows the mock up of bolting a couple pieces or frame on place to extent... I later cut the extra TRX-4 frame and brazed it in place
Then testing the body height, had to trim some outta the floor boards to clear the transmission
Played a lot with a site called tinkercad so I could bring in the 3d files and manipulate them, adding things like the fuel tanks and resizing.
I finally decided on putting the ESC up front here, hood is held down with magnets
And the receiver under a magnetic lid back here.
https://youtu.be/VYjQ-AzIWIY
And not sure how to make a video link work so there is a small and albeit crappy video of testing the drive line and shifters then the battery died
Still a lot more work to go, but it's a start.
Evilsage is offline   Reply With Quote
Old 08-06-2019, 02:14 AM   #2
Default Re: TRX-4 6x6
Nice build. How did you make the extra output shaft on the trans?
Desmo is offline   Reply With Quote
Old 08-06-2019, 04:20 AM   #3
50mm x5mm drive shaft piece from in my shed of random bits, not sure what kit it originally came out of. but it had a screw piece on the end as if it had a slipper clutch assembly at one point
Old 08-06-2019, 10:17 AM   #4
Natedog's Avatar
Wow, that's hot! Nice body choice and great work, keep it up!
Old 08-09-2019, 06:45 AM   #5
This is really cool. Nice work!
chino is offline   Reply With Quote
TRX-4 6x6 - Similar Threads
My HG601 6x6 aka The Dubsta 6x6 W1ck3d0n3 Multi Axle Rigs 5 12-21-2020 02:17 AM
TRX-4 6x6 Military Utility Truck robysoldtamiya Traxxas TRX-4 14 09-11-2019 01:06 AM
Another SUX 10 based 6x6 Traptor build, named Texas Pete. And it's not 6x6 yet, I ran tcanin00 Multi Axle Rigs 11 05-26-2019 04:49 PM
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** dankycrawler Multi Axle Rigs 37 04-18-2013 02:09 PM
