12-14-2011, 09:58 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: ZETROC
| Dirt riot!!!! Stock class!!! this means that with a few upgrades to a stock vechile you could race it in the stocker class!!!!!! 11-09-2011, 09:53 AM #1 Big Rich W.E.ROCK CEO Join Date: Jan 2001 Member # 3123 Location: Blackfoot, ID (almost BFE) Posts: 7,666 Dirt Riot Trail Class Rules - Frist Draft Let's discuss..... Remember this is supposed to be a class that most can jsut add safety items and come out and try this racing thing I'm not looking for a 20 page rule book or to add more than 2 trail classes Both trail classes and the UTV will race on the course as a group, no pro classes will be mixed in with them (exception will be Badlands, possibly), the races will be 1 hour in length at all venues ************************************************** ****** Dirt Riot Trail Class Rules These rules are intended to promote a safe and fair racing environment, these classes are open ended in many aspects due in large part to allow as many already built trail rigs to compete with a minimum amount of changes. Changes to these rules may occur at anytime during the racing season, rules changes will be posted on the follow websites; werocklive.com, W.E.Rock Events facebook page, pirate4x4.com, direct contact with competitors may occur but is not guaranteed. Stock Trail 1. Frame must be stock full frame (exception, when bobbing the rear then only can a minimum amount of frame be removed, equal to the amount of body removed), with all cross members (exception, frt. Cross member with changing to a straight axle). 2. Suspension type must remain the same as OE, per vehicle production year, make and model. 3. Any axle up-grade is ex-acceptable 4. No tire greater than 37” by sidewall listing or metric equivalent 5. Full body vehicles only, bobbing is allowed between rear axle and rear bumper, but at least 24” must remain from centerline of axle to rear of bumper, no dovetailing or boat siding allowed Modified Trail 1. Must have body panels including hood when starting the race 2. Any suspension mod’s allowed 3. Stock or round tube chassis’s are acceptable Both Classes 1. No By-pass type shocks allowed in mod trial, coil-over shocks are acceptable 2. 6 point cage of acceptable design and configuration, must be at least 1.5” .120 wall or greater and magnetic steel material 3. Minimum of 4 point harnesses must be used for both driver and co-driver; they must be in good shape and show no signs of wear or weather damage, condition to be decided by a Dirt riot “Official” 4. Side protection/Door bars required 5. Minimum 6000lb front mounted winch wit synthetic winch line, winch must be operational 6. Solid roof required, magnetic metal of at least .040 or aluminum of 1/8” in thickness acceptable 7. Complete floorboard and firewall required, firewall must extend from inner side panel to opposite inner side panel, and from floorboard to engine hood. 8. Fuel cell/gas tank must be separated from passenger compartment. Fuel cells must be strapped and not flange mounted 9. Minimum 2 5lb fire extinguishers must be mounted within reach rescue personnel, and mounted in such a way as they are secure but easily accessed when needed. 10. Seats must be mounted securely to the cage or floorboards 11. All Wiring, brake lines, fuel lines and vent lines must be in good condition and secured as needed 12. Battery must be of a dry cell or gel cell construction and securely mounted with a cage, box, or over the top strap. 13. Rear facing amber light must be visible to rear approaching vehicles; light must be hard wired so it stays on with ignition switched on 14. Vehicles must be equipped with differential locking devices in both front and rear axles 15. Vehicles must be equipped with beadlock wheels 16. Vehicles must carry a small first aid kit with these items: __________________________________ 17. Driver and Co-pilot must wear helmets, helmets must be dot, SNELL or FIA approved. Helmets must be current in dating and in good condition. 18. High back seats or helmet pads must be used 19. Neck support devices are highly recommended 20. 1 piece fire suits and shoes are highly recommended __________________ Thanks to our marketing partners: MAXXIS Tires, Torchmate, King Shocks, Master Pull, SpiderTrax, Advance Adapter, Trail Gear,and Raceline Wheels Quote: Originally Posted by ZUKROVER 4 wheeling sure changes when there is a crowd and cones. W.E.ROCK aka World Extreme Rock Crawling | Competitive rock crawling at it's best, West, East and Regional events.W.E.ROCK aka World Extreme Rock Crawling 530-417-5333 Rich C Klein | Facebook Rich Klein (Big Rich) on Myspace ( @ Y @ ) ( * Y * ) ( . Y . ) event schedule: Dirt Riot 2012 Schedule Southwest Series January 13-14 Southwest 1 Tucson, Arizona March 16-17 Southwest 2 Hungry Valley SVRA Gorman, CA May 8-19 Southwest 3 Congress, AZ Central Series March 9-10 Central 1 Altus, OK April 13-14 Central 2 Sayre, OK May 11-12 Central 3 Fredericksburg, TX Pacific Series March 23-24 Pacific 1 Marysville, CA July 6-7 Pacific 2 OR/NV/Nor Cal August 10-11 Pacific 3 Washington Great Lakes Series June 8-9 Great Lakes 1 Harrison, MI June 29-30 Great Lakes 2 Marseilles, IL August 24-25 Great Lakes 3 Attica, IN Mountain Series April 6-7 Mountain 1 Moab, UT (EJS) June 15-16 Mountain 2 Colorado Springs, CO July 13-14 Mountain 3 Cortez, CO International Series September 1-2 International British Columbia, Canada National Championship Race October 12-13 Dirt Riot Rampage Mid-West |
12-14-2011, 05:00 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Aztec NM
| Re: Dirt riot!!!! Stock class!!!
Guess I have to get the Jeep Done maybe its the fire under my ass that I need. You Mr. Cody better get one of those Cherokees done!!
12-14-2011, 08:12 PM | #3 |
| Re: Dirt riot!!!! Stock class!!! |
