01-26-2013, 09:35 AM | #1 |
Newbie Join Date: May 2012 Location: Albuquerque
| NM crawlers, I need a radio!
Good morning Guys and Girls, So I finally put my CC BEC in my Losi and hooked it up as instructed on the diagram that came with it. Long story short, it fried my receiver in about 3 min of light running. I am trying to see if anyone has a spectrum or older futaba they might be willing to part with cheap. I have exactly 50 dollars to my name right now and that is the best I can do. I can afford to get a flysky fs-gt3b but it is doubtful I can get it here in time. The only other option I can think of is if one you has a stock losi receiver that you don't use. I would be willing to buy that too if you think it would work. I looked on Losi's site and they want almost 50 dollars just for that. I have gone through the for sale section and several of the radios for sale are already gone or come as a package deal or without a receiver. If any of you have something that might work for me, please try to hit me up today cause if there is nothing local, I will need to order that flysky today in hopes that it gets here before the comp. Thanks All, Mike |
01-26-2013, 09:55 AM | #2 |
Pebble Pounder Join Date: Jun 2012 Location: las cruces
| Re: NM crawlers, I need a radio!
What voltage is you bec set at and I don't have a spare just my 4pl
01-26-2013, 10:14 AM | #3 |
It is set at 6 volts. I hooked it up and put on my 2s 1300mah 15c battery and tested. At first, there was resistance to drive forward or backward. Then it started to clear up. I started up a modest climb on a homemade course and it just stopped. No forward, no reverse, only the steering servo responded. I read a forum that some receivers can't handle the constant voltage and you should wire the servo directly. Fortunately I didn't cut wires I just removed pins and I was able to reconnect the esc to the receiver and direct wire the servo to the bec. The result however is a crawler that turns when throttle is applied, forward or reverse. I have tried moving wires to reduce any kind of interference but I get the same results. When I saw the price for a receiver replacement, I figured I would try to get a new radio. So here we are.
01-26-2013, 10:33 AM | #4 |
Rock Stacker Join Date: Feb 2011 Location: Santa Fe
I have a dx3e combo. I live in Santa fe. Call me if u r interested 204-5571 mark
01-26-2013, 01:27 PM | #5 |
That's weird man maybe try to reprogram your radio or rebind it what li.d or radio is it I only have axial and my 4pl experience
01-26-2013, 02:53 PM | #6 |
Rock Crawler Join Date: Jul 2012 Location: Albuquerque, New Mexico
Last time I was there, the indoor track on Eubank had some used spectrum receivers. Under $40 I think. And if you are using the losi radio the spectrum receiver should work. Shot me a pm if you don't find anything before the next comp and I'll loan you one of mine.
01-27-2013, 02:20 PM | #7 |
Many thanks to everyone for the help. I purchased the DX3 from 505kustomz (Mark) and it works great. It also has me one step closer to a pro comp truck. I am slowly acquiring the pieces as I go and will likely be ready for pro next season. But for now, I finally have a BEC driven servo and it definitely makes a difference. Next step for the tortuga is better batts. The 15c just ain't cutting it. Are there any brands of batts you guys would say to steer clear of?
NM crawlers, I need a radio! - Similar Threads | ||||
multiple crawlers, 1 radio? | LIKES2CRAWL | Electronics | 5 | 08-27-2005 03:04 AM |
