01-12-2008, 04:57 PM | #1 |
Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
| axial stage 2?????
Ok I have every mod for the stage two build done using extra parts left over from my axial kit except the extended upper links. All I have bought so far for the stage two kit was a set of tcs crawlers bent links for $15.99, a set of internal springs for $4, and 4 dubro 4-40x1 1/2 inch bolts. Now after all my rambling lol I am going to cut my old lower links and use them for uppers. Should I cut them to 76mm and forget about using the 6x6mm spacer or should I cut them to 70mm and cut a few 6mm spacers out of the extra lower link to use? Thanks for your help Justin |
01-12-2008, 05:30 PM | #2 | |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
i would cut them at 76. | |
01-12-2008, 05:33 PM | #3 |
Ok I didn't know if the spacer served a purpose or not. What size tap will I need to re-tap the end of the link I cut? Thanks Justin |
01-12-2008, 05:41 PM | #4 | |
3mm, also use a brake line/tubing cutter to cut the aluminum. well, now that i think about it, if you cut them at 76 it might be to wide,if you using the stock 3 link, just try it. like i said earlier you can cut them down if needed. are you using 4 link or 3 link? Last edited by yotachump; 01-12-2008 at 05:53 PM. | |
01-12-2008, 08:42 PM | #5 |
stock 3 link. I've already cut them down with a pipe cutter but sears didn't have a 3mm tap and everything else is closed so I couldn't tell ya if the 76mm works or not. bu thanks for your help
