02-04-2008, 06:46 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| Did I fry it
Ok, I hooked my esc XL1 up to a 7 cell battry 3000mah battery, it ran for about 5 minutes then stopped. I checked the heat and it was quite hot not sure how hot thow, The specs say it will handle up to 7 cells and up to 10 volts any ideas? Im running two 45t's the xl1 and a futaba skysport radio. it ran ok usung a 6 cell, i was trying to boost the power and run time. thanks in advance.
02-04-2008, 07:15 PM | #2 |
Rock Stacker Join Date: Nov 2007 Location: Crawlafornia
| fryed....
hi ken ! It should be fine with the extra cell and not always, but most times they smell kinda wierd after burnin up. Check for loose connections and possibly shortsC ya and good luck!
02-04-2008, 08:10 PM | #3 |
Pebble Pounder Join Date: Dec 2007 Location: NIPOMO!!!
affraid to say, proly fried it. i just smoked two of mine. there is a up side though, if it is fried, take the cover off the esc, and start touching the circut bored to a 12v car batt, and look for the mystery blue smoke.
02-04-2008, 08:42 PM | #4 |
I took it apart and there was white goo coming out of the heat sinks, oops, i connected my batteries up +-+-+- for the 7 cells and checked the voltage and it read about 8.4 so i cant see were there would be a short. I guess im ganna have to get a rooster from novak, it can handle 7 or 8 cells correct?
02-04-2008, 10:30 PM | #5 |
Rock Crawler Join Date: Apr 2007 Location: portland
02-05-2008, 07:54 AM | #6 |
Thanks guys for the info.
