02-13-2008, 06:07 PM | #1 |
Newbie Join Date: Jan 2008 Location: grand junction
| she wont drive
i just purchesed a axial ax 10 scorpion , a spektrum dx 2.0 (radio ,receiver, and 2 servo system) and a novak brushless goat system with motor and speed control. and i got it all built and ready but i cannont get it to go. it turns on and i got the remote and receiver to synk using the instructed method but it wont do anything. can someone please help me.
02-13-2008, 06:29 PM | #2 |
Rock Stacker Join Date: Jan 2008 Location: Connecticut
Sounds like the receiver is not bound correctly to the radio. Do you have steering and just no forward/reverse?
02-13-2008, 06:52 PM | #3 |
nothing will work
02-13-2008, 06:55 PM | #4 |
Rebind the receiver to the radio and then do your setup for the speed control. You may have to power the receiver with a seperate battery pack to bind it then plug in your speed control after it is bound and power up. Then see if you have steering. If you have no steering its a radio issue which means its not bound properly....
02-13-2008, 08:27 PM | #5 |
Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
Or the plugs on your receiver are backwards. If the radio thing dont work pull the plugs flip them and see if that works and make sure all the plugs are the same way. Hope one of us has helped you!!! |
