02-17-2008, 09:41 PM | #1 |
Pebble Pounder Join Date: Jul 2004 Location: College Station
| BEC Wiring verification
I have a mamba max esc and tq3 reciever with this split 8 cell battery. http://www.tcscrawlers.com/TCS-8-cel...n-p-16620.html I was wondering which diagram im suppose to be following to install a cc BEC. http://www.castlecreations.com/products/cc_bec.html# I'm guessing the diagram on the right since i have a split cell battery pack. The cc bec radio ends plug into the the rx and i just unplug the red wire that goes from the esc to the rx? Also i have the castle link program and wire that came with my mamba max esc/motor combo. Can i use that to program my cc bec? thx, im just making sure before i see smoke. |
02-17-2008, 09:44 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Your pack is split...........but it is still a single pack with a single plug. You would follow the diagram on the left. To program your BEC, you will need the hardware link that comes with the castle link. |
02-17-2008, 09:46 PM | #3 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
don't forget to disable the BEC on the ESC, the printed instructions on mine didn't say anything about it but its very important |
02-17-2008, 09:50 PM | #4 |
| I cut my on/off swtich wires awhile back. I soldered them together. Basically its always on, to turn my rig on i just plug my batts together. Is removing the red wire coming from the esc to the rx disabling the bec? I hope my on/off switch has nothing to do with it.
02-17-2008, 09:55 PM | #5 |
| My mamba max esc came with "castle link" cd and cable. I'm gussing its the same one used to program both Mamba Max esc and CC BEC?
02-17-2008, 09:59 PM | #6 | |
the link that you need for the BEC is the same that you get for the Mamba 25, the one with the shrink wrapped Circuit board http://www.castlecreations.com/produ...stle_link.html | |
02-17-2008, 10:05 PM | #7 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Ha, don't trust me huh??
02-17-2008, 10:09 PM | #8 | |
If i leave it stock with 5.1volts, is it better than my stock bec on my mamba max esc for a 2.2 comp rig with front steering and a servo for the dig? | |
02-17-2008, 10:12 PM | #9 |
02-17-2008, 10:14 PM | #10 |
it will have lower voltage but the amp draw will be what you want, If I were you I would ask around one of you're friends or guys at the LHS might have one you could borrow |
