Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: mercedes G body, short wheelbase
Old 02-21-2008, 02:55 PM   #1
Default mercedes G body, short wheelbase
I have a mercedes G (short wheelbase !!!!), and yes, it is a toy.:-(
The reciever is connected with the car by a wire !
The steering is with a wheel on the reciever, and works with a steel cable, through the wire to the car ! (yes, i know, it sounds ... 'old' ).
BUT, the body is perfect ! And i don't find the same here in the forum !!
I want to transform the car, only by using the body.
Now my question, which chassis can fit, or modified to fit ?
And most important, which axles ? ( so that the tires don't come out too much )
wheelbase = 30 cm = 11,8 inch
body width = 20,5 cm = 8 inch
tire high = i thought maximum 10 cm = 3.94 inch to look scale.
I thought to buy the ax10 to start with,
it will be my first project !
thank you !
hzj 74 is offline   Reply With Quote
Old 02-21-2008, 03:07 PM   #2
that seems like a good body for a 1.9 scale truck. if i were to build it. i would try to buy a set of tlt or axial axles used somewhere,then a tranny and a scale chassis. this would be cheaper then buying the ax-10 kit and would give you a better start
haynesn12 is offline   Reply With Quote
Old 02-21-2008, 03:32 PM   #3
~THE SCALE SHOP~
TLT axles would be a great match for that 8" width.
STANG KILLA SS is offline   Reply With Quote
Old 02-21-2008, 03:58 PM   #4
Have any pictures?
AeroSynch is offline   Reply With Quote
Old 02-21-2008, 04:41 PM   #5
axial axles are 1/2" wider than TLT's so I second the TLT axle recommendation. This sounds like my gwagon, but not really...pics please.
This is my gwagon (Nikko toy body) with TLT axles under it.
pantablo is offline   Reply With Quote
Old 02-21-2008, 05:04 PM   #6
Check out this link for what can be done with a G-Wagon
http://www.offroadrc.ca/showthread.php?t=23329
Shaggy5050 is offline   Reply With Quote
Old 02-21-2008, 05:28 PM   #7
tjb
Yup, I already have a 2-Door pick up in the works for my next build. Just waiting for the body to get here
Those look a bit smaller than the Nikko Body
tjb is offline   Reply With Quote
Old 02-21-2008, 05:29 PM   #8
Those are nice builds, but they are 1/12...
Pretty cool though. :-P
Old 02-22-2008, 12:33 AM   #9
hahaha, those were hilarious. I like the pick up bed though...maybe when I'm done with the rover and need something to occupy my time I'll do a soft top 4dr pickup conversion...hmmm...
Old 02-25-2008, 12:14 PM   #10
here some pics of my G 'toy'
i think it's possible to make something really nice with the body ??
And thanks for the answers so far !
Old 02-26-2008, 05:53 PM   #11
That does look like a capable body. I like how it is a mini pickup version. I say go for it.
Old 02-26-2008, 06:52 PM   #12
That looks really cool, with the tailgate and all! Seems like a good base if you wanna do some tube work it would be awesome!
clod freak is offline   Reply With Quote
Old 07-20-2008, 12:52 PM   #13
i made a decision,
an ax 10 kit is on his way to belgium, (i hope it arrives soooooon .....):-P
and also 1.9 tires
yes, it took a while, because i read a lot on this forum to learn, and learn and learn, ... (and i stil know nothing )
i started to make my own chassis, of metal. I know it will be heavy, but metal i can weld, not alu.
i started from photos of the G wagon chassis, my 1:8 scale body, and paper to draw.
Now the chassis is 'almost' ready, but i am waiting for ax10 to arrive, because i want that the tranny fits exactly between the chassis.
By the way, is it normal that i feel me like a little child that knows that it gets a very big present of the santa claus ?????
Old 07-20-2008, 09:30 PM   #14
I like that body. and yeah that is totally normal..
sloppy is offline   Reply With Quote
Old 08-29-2008, 05:49 AM   #15
the ax10 arrived :-P
I built my first chassis , (i'm proud on myself)
and there is still a lot to do ...
the stock springs (with blue dot, super firm) are too strong.
i thaught to buy a set of medium and super soft, to try out.
has anyone a suggestion ?
and after the springs, then still the shocks ...
Old 08-31-2008, 12:47 AM   #16
looks good. with that being a 1/8 scale body you could go with more offset on the wheels so they don't get sucked into the wheel wells. They look like they could stand to sit out 3-6mm farther than they are now.
Old 08-31-2008, 11:31 AM   #17
more offset whould be ok. maybe i do that later, first make it 'a roller'.
by the way, pantablo, your g looks great !
Old 10-19-2008, 12:52 PM   #18
So, my G drives ...
first, i drove with the 1.9 wheels, and yes, i was happy ...
but, i was a little disappointed by its performance:-(, i thaught it was because of the heavy weight,
but today i mounted the stock 2.2 wheels of the ax10 on it, AND :-P
yes yes yes, it is a totally oder G-wagon, it's unbelieveble what a difference it makes.
where the 1.9, i have to try 10 times, (and have a lot of luck), now with the 2.2 i can drive with out a problem , its a LOT of difference.
here are some pictures ... and yes i have still a lot of work to do
and on the last pictures, you can see where i will make my private rock-crawling area ... only most of the rocks (stones) are not yet there ....
Old 10-20-2008, 06:31 AM   #19
Wow, that looks very nice.
salmonfacesalad is offline   Reply With Quote
Old 10-22-2008, 04:47 AM   #20
Very nice your G, althought I like them a little more civilized.
Anyway do the finishing , nice rig.
In which corner of Belgium are you?
Cheers, Serge
mudzuki is offline   Reply With Quote
