03-02-2008, 03:17 PM | #1 |
Rock Stacker Join Date: Aug 2007 Location: in a house
| batteries for crawling
with my scorpion i have 5 3700 on there now will that work or should i go with more then 5
03-02-2008, 03:51 PM | #2 |
Quarry Creeper Join Date: Jan 2007 Location: Kansas City
Depends on the voltage of your ESC. How many volts can it handle? I personally run no less than 7 cells
03-02-2008, 05:09 PM | #3 |
i have a mamba max on there
03-02-2008, 09:34 PM | #4 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
Agreed 7 cells minimum. The additional voltage makes a big difference. Look seriously at 3s lipo if you have the money or a charger that will charge them. If you're on a budget, 8 cell saddle packs on the front axle are your best bet.
03-03-2008, 06:28 PM | #5 |
ok so cant i go with a 65 turn and 90 for the gear wount that make up for the lost cells
03-03-2008, 06:34 PM | #6 |
You wont get the needed amp draw on 5 cells. Use 10 cells if you don't want to buy new packs, run them in series. I run 10 cells or 3 cell lipo generally. |
03-04-2008, 07:32 AM | #7 |
ok so will 6 cells on a stock wk esc work then
03-04-2008, 11:44 AM | #8 |
Pebble Pounder Join Date: Dec 2006 Location: college station
That esc will handle tons of power. I run cheap motors and 3s lipos to get them to perform. 7-8 or up to 10 cells NiMH would be good alternative. 10 if you can handle the weight and placement.
