| | #1 |
| Rock Stacker Join Date: Nov 2007 Location: Sacramento
| I have a Hitec 5955TG, Mamba Max, and a Spektrum 3001 receiver system (2.4gHZ). I have been running this new servo for a few days and seem to get some radio noise out of the thing, (great servo as far as torque goes.) When I am turning my crawler it will make some strange radio noise, which I expect when it is moving, but when I return the servo arm to neutral (straight up, down) It will continue to make the "noises" kind of a whining sound almost like radio interferance, but I am using 2.4gHZ radio system. The only way that the "noise" stops is when I throttle the rig for a second, but once I turn the wheels it will stick with the radio "noise". I am not sure if the servo is under powered, like it might need a BEC or something. Any help would be greatly appreciated. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Jan 2005 Location: Hueytown, Alabama
| If your talking about the wining noise it makes, its just trying to find center. All digital servos that I have had do this. The reason it stops when you bump the throttle is because your taking the weight off the front of the truck and making it easier to center. |
| | #3 | |
| | #4 |
| Quarry Creeper Join Date: Jan 2008 Location: Switzerland / Geneva
| Even noise problem with my servos |
| | #5 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| It is overworking, but thats what high resolution digital servos must do to find center. They work alot. You should be running a CC BEC or another form of external BEC using that servo and the Mamba Maxx (worst internal BEC in ESC). |
| | #6 |
| I also have a BEC external, but always the little noise acute |
| | #7 |
| Southern buggy whore ![]() Join Date: Jun 2007 Location: Canada, eh.
| I've also found that touching the steering just a tiny bit to one side or the other will often stop the chirping. As others have said though, this is common with digital servos. |
| | #8 |
| Humm ... OK ... I will live with this "noise" |
| | #9 |
| Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
| yea i have the same servo and have the same noise |
| Thread Tools | |
| Display Modes | |
