04-22-2008, 03:47 PM | #1 |
Newbie Join Date: Apr 2008 Location: Champaign
| Oh no, not another "Mini-me truck" thread!
As the title implies, I want to build a mini of the truck I used to own - 1996 K1500 Silverado. I've done some research, and I've found the only appropriate body [88-98 bodystyle, reg cab, short box [fleetside]] at Parma for $25. http://www.shopatron.com/product/par...7259.17973.0.0 Next, I started looking at axles: I want to use the scale D60 if possible, from RC4WD [looks similar to a 14SF/FF] for $150. http://rc4wdstore.com/product_info.p...roducts_id=672 For the front end, I have a different idea. Since I want it as similar as possible to the 1:1, I want to try to do a 4x4 IFS up front. My question is, where do I get the components from? The diff, control arms, knuckles, steering, etc. Is there any good model out there that I could yank it from? And would the gearing be the same as the D60? After that, transmissions: My initial thought is an R2HD for $100, because they seem to be popular, easy transmissions. Any thoughts on this? Do I want a 2 or 3 speed instead? Then, motors: Honestly, clueless here. What are some good recommendations? Preferably plenty of torque but not ultra-slow. Then, all the other little parts: Driveshafts - would Punisher shafts work? Or should I get something else? Shocks - Since GM IFS is/was torsion bar from that era, I won't be able to do that - so I'm opting for some internally sprung shocks from RC4WD. What about the rear? I want some w/o internal springs, because I plan on doing leaf springs in the back, probably from a HighLift. Wheels/Tires: First, does anyone make BFGoodrich A/T scalers for 1.9's? That's what I would be running. If not, I'll find something I like. Note: If the IFS is too impractical, then I can just switch over to solid axles - probably TLT axles. Thanks for any input and help on the subject! I am willing to lift it more than the 1:1 was if I have to [probably will have to]. And here's a picture of the 1:1 I don't have any more. |
04-23-2008, 11:39 AM | #2 |
NO ONE knows any answers to any of my questions?
04-23-2008, 11:51 AM | #3 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
To get the gearing to match up with a solid axle rear and an IFS front, you'd probably have to do something like this. Or make the front end components yourself. Indy V2 (the rebuild) Or go 2wd...... pre runner build.. |
04-23-2008, 11:53 AM | #4 | |
Rock Crawler Join Date: Sep 2007 Location: University City
Ok im gonna take a shot at helping...so bear with me...answers are within the quotes. These are mostly opinion and what ive seen...but alteast its a start. Quote:
04-23-2008, 11:53 AM | #5 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
| The RC4WD axles should work great for the rear end of that thing. If you haven't, you may want to surf the scale forum to see what people are using. Maybe cross post this there? Re: the front end, you'll probably have to make or adapt parts from other cars. If you can pull it off, that'd be really cool, despite hampering crawling performance. Search for torsion 2.2 setups. Your dream of a torsion sprung front end may be more realistic than you thought. Re: transmissions, I don't know much about the R2D, other than that they tend to be noisy. I'm really happy with the tranny in my Axial setup, and you may be able to save some money that way. re: Motors, the standard 55t would be a great choice. Maybe 35t if you're going to use this as a basher instead of a crawler. More info about your budget here would be useful. The bomb would be a cobalt puller from JRH. Re: driveshafts, pretty much anything would work. This will be partly driven by your transmission choice. The punisher shafts seem to wear out too soon for the money. For shocks, post in the scale forum. They can probably help you more than I can. |
04-23-2008, 11:59 AM | #6 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
| Sometimes you need to give it a bit , or post it in the general scale section... It comes down to what you can spend and how scale you want it to look. What are your fabrication skills? If you're looking for a bolt together project, it would be possible, but unless you could make your own stuff, you will only get close to looking the way you truely want.. What chassis do you plan to start with??????? sometimes it works better to go chassis up, not body down. Here are a few...... Tranny, The R2HD would be fine in it, but unless you plan to beat the piss out of it, the regular R2 would be cheaper.. Motor, 35T lathe.... Axles, TLT More bang for your buck My suggestion, find a CC-01 put a 35T lathe in it and you would have something very close. I would "live" in the scale sections and do a fair amount of looking through threads in there.. You will see a good amount of ideas |
04-23-2008, 12:23 PM | #7 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
What you are planning to build is a Tamiya CC-01. I'd just get one of those (Tamiya Volkswagen Touareg is the Long WB version) slam a 55t motor in it and put your body on and call it done. It already even comes with a set of 1.9 BFG's.... All for about $165 brand new outta the box. And it will be WAAAAY less work than what you have planned. |
04-23-2008, 03:04 PM | #8 |
Ahh..thanks for the replies! I've been doin a good deal of lookin in the scale sections. In terms of chassis, are there any good recommendations? I want a truck-like one (not a comp crawler box-like one). If all else fails I'll make my own.
