04-30-2008, 07:38 AM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: West Liberty
| Wrapping your antenna wire *Best Way?*
I was wondering (as I'm sure some noobs are aswell) if a few of you vets had a particular way you wrap your antenna wires to keep them underneath the body and out of harms way for sharp rocks. I can't stand how mine is just hanging out there through the back/top of my body and was wondering how you guys keep them hidden. Also, Is there a better chance of interference if it is wrapped a certain way? I once read not to "double over" the wire because it will reduce the range..True or False? Pics would help if it's not too much to ask, I just want to get a general idea. Thanks -Tim |
04-30-2008, 07:43 AM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Jonesboro, Arkansas
I like using the lexan strip, It works great |
04-30-2008, 07:48 AM | #3 |
That's the type of pic I was looking for, Thanks! Just so I'm clear, Just zig-zag it through the holes in the lexan strip right?..Not letting them "cross the streams" to quote a great movie from back in the day... Thanks -Tim |
04-30-2008, 07:50 AM | #4 |
RCC Addict Join Date: Aug 2007 Location: Toronto, Canada
x2 on JBHardwear's lexan strip. I had a similar design ziptied to the back of my rig. But eventually I didn't like having it looped on the back and I didn't want to have it free floating like how JB has it shown in his picture. So I decided to try my own idea. I cut a spare antenna tube into smaller half sections and then fed the antenna wire into the tube and the tube through the screw mount holes in my SW3. If I change up to a Spektrum eventually, that wire will be so much shorter and easier to hide. |
04-30-2008, 07:53 AM | #5 |
| Thats it, just zig zag and dont cross them |
04-30-2008, 08:08 AM | #6 | |
Pickup some lexan from the LHS, drill some holes, feed it through a hole and loop it around and if you want to skip a hole, go for it. Play around with what works with the length of antenna wire you have. I have a lexan strip installed on my micro rs4 racer. | |
04-30-2008, 08:11 AM | #7 |
Great, Thanks guys. -Tim |
04-30-2008, 11:17 AM | #8 |
Pebble Pounder Join Date: Jul 2007 Location: USA
04-30-2008, 11:45 AM | #9 |
Quarry Creeper Join Date: Jan 2007 Location: US
That worked for me till I ran it in my stadium truck. Then again, I had a buggy body with a truck body over that.... the distance just wasn't there. It worked fine up close.... so probably fine for a crawler... but for wide open parking lots, it didn't work far enough away. Oh yeah, running cheap futaba gear... maybe that was part of it.
05-01-2008, 07:10 AM | #10 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
Another product to consider is coriplast - the corrugated sheet plastic that you see signs made out of. I made an "antenna holder" last night by cutting a small square piece of coriplast and running the antenna through the corrugations - one run of wire per corrugation. I then zip tied the whole thing to plastic electronics tray on my crawler. Very small and compact and works perfect. Sorry I am at work and have no pictures!
05-01-2008, 07:13 AM | #11 |
Either way, Still a great idea..Especially to use on those voting signs people always see laying on the side of the road. Thanks for the suggestion! -Tim |
05-01-2008, 06:54 PM | #12 |
RCC Paint & Graphics Join Date: Oct 2005 Location: Wauseon, OH.
This is what I did with my antenna. I took some 12" antenna tube and put small bends in it by heating it with a lighter. The amount of bends will depend on the length of your wire. Once you have it to the length you need it, feed your wire through. This can make a nice, clean install. |
