05-09-2008, 03:08 PM | #1 |
Newbie Join Date: Jan 2008 Location: Austin
| Running two four pack sub C's in series OK?
I plan to run two separate four pack 4700 mah Sub C's in series using a custom harness for 9.6v. I'll charge them separately. Should be ok right? Any issues I should be aware of? |
05-09-2008, 03:42 PM | #2 |
Shouldn't be a problem, I've done the same but with 6 cell packs.
05-11-2008, 01:10 AM | #3 |
Rock Stacker Join Date: Apr 2008 Location: houston
no problems there
05-11-2008, 01:20 AM | #4 |
If you will be using them in series, it is best to charge in series. If they haven't been used together (or balanced in a while) I recommend discharging them at 1c and charging at .1 to .2C a few times to balance them first. Then discharge both and recharge in series.
