05-23-2008, 11:21 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: Firestone
| Travel Limits
Another noob question for you guys. I have been looking around have not been able to find any posts on how much to limit your travel. I have a basically stock ax-10 and right now it has almost 90 degrees of travel, way to much I know. I am going to ad stops on the inside of the shock and was wondering how much travel you guys recommend. What should I shoot for? Thanks in advance.
05-23-2008, 11:56 AM | #2 |
Rock Crawler Join Date: May 2007 Location: Norwich
I run between 45 and 55 degrees of articulation. 90 is way too much. You could use a limiting strap.
05-23-2008, 12:27 PM | #3 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
Lots of personal preference on this question but I like just enough to clear the same size tires I'm running. That means I can lift one tire just over five inches off the ground which puts me in the 40 degree category but the 45-55 seems pretty standard.
05-23-2008, 01:46 PM | #4 |
Cool I was think about 45 degrees. I wasnt to far off then. Now I just need to figure out the best place to put the limiters. Thank you.
05-23-2008, 01:58 PM | #5 |
After moving the stock shock spacer to the inside try some fuel tubing on the outside of the shock shaft. If you need more than 2 inches of it between all four I'd be surprised. Somewhere in the neighborhood of 1/2 inch each would be a good start. You can always trim it down.
