05-23-2008, 07:10 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Duchesne
| building a super class rig
i have been building a tuber to be in the super class and wanted to know what works better on a super class rig a dig setup or 4 wheel steering? thanks in advance.
05-23-2008, 11:02 PM | #2 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
| Super class rig Most Super class rigs run Clod style axles with two speed controls so you get both, dig and 4WS. Even if you run a shaffty you can have both.
05-24-2008, 04:32 AM | #3 |
Newbie Join Date: Mar 2008 Location: Northeast
Both, get a nice stick controler..
05-24-2008, 07:11 AM | #4 |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
I agree; go with both dig and 4WS. You'll use both and often in different ways for different reasons. The Nomadio React is under $300 and is a 4-channel pistol grip control. I'm sure someone has setup one up for a Super with 4WS and dig. You could also look into running the dig using a on/off switch to cut power to the rear motor. That would save you from buying two ESCs.
05-24-2008, 09:00 PM | #5 |
ok sounds good guys thanks for that help. I think i will put the 4ws on first, and then put the dig setup on later. when I start doing comps. thanks again for your help.
05-24-2008, 10:58 PM | #6 | |
RCC Addict Join Date: May 2008 Location: On the rocks
05-25-2008, 10:33 AM | #7 |
also one more question will zip ties work to hold on the aluminum panels that I want to make for the chassis or will they just make the crawler look stupid? thanks
05-25-2008, 12:28 PM | #8 |
05-26-2008, 12:16 AM | #9 |
ok zipties it is then I got hte roof cut out and painted today so tomorrow I will try to make the two side panels and the hood panel. and see if I can get them painted up I don;t know why I'm painting the panels though cause they will just get all scratched up on the rocks but I guess I can always repaint the when the paint gets really bad. anyway thanks for the help. I will use the sipties to hole them on.
