06-07-2008, 10:55 PM | #1 |
Pebble Pounder Join Date: Apr 2008 Location: springfield
| 7.5 oz good place to start?? ax10
is the 7.5 oz a good place to start when weighting the front wheels. I have stock rims with rock claws. they are weighted now from the previous owner and weigh a total of 8 3/8oz, that includes the tire, rim, weights. they are weighted on the outside http://img.photobucket.com/albums/v4...0/P1030119.jpg and today i got some stick on weights. so i was going to redo them. |
06-08-2008, 12:26 AM | #2 |
Pebble Pounder Join Date: Feb 2008 Location: Reno
Not a bad place to start. You'll probably want to add some weight to the rear. It will help with downhilling.
06-08-2008, 12:34 AM | #3 |
Rock Stacker Join Date: Dec 2006 Location: in front of a computer
thats a good place to start. dont add any weight to the rear, it makes some steep climbs alot harder then they need to be.
06-08-2008, 01:01 AM | #4 |
well i added 3 more oz of stick on weights to the inside of the fronts, and cut the foam to a star pattern, the rear already has 3 oz of weights on the outside of the rims just like the front. i will see how this does and go from there
06-08-2008, 01:14 AM | #5 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
I added 6oz. to the front wheels on my AX-10 with the stock tires and Proline Memory Foams and it made a very good improvement. I found that I need to add some weight to the rear wheels though. As mentioned above it will help with downhilling. And I noticed that without any added weight in the rear wheels the suspension was not able to work as smoothly. So I added 4oz. to the rear wheels and although I have not run it yet I know this worked on my other crawler. |
06-09-2008, 04:39 PM | #6 |
Newbie Join Date: Jun 2008 Location: saline
is there a certain brand of weights that seem to work better then others?
06-09-2008, 05:22 PM | #7 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
My front wheels weigh in at 13 oz ea. My rears are at 8 oz each. I use the dubro wieghts that you usually find in the hardware section at you hooby store. Tire weight has a lot to do with your terrian. Also throw your battery on the axle for some more foward bite. Down here in southern AZ we have enough traction to make so 65 to 70 deg climbs so we have alot of bite and use the heavy tires to get the grab
06-09-2008, 10:56 PM | #8 |
Rock Stacker Join Date: May 2008 Location: MIDDLE OF THE DESERT
On my Scorpion I have 54 oz in front and my second battery in back. First real test will be Saturday at a place called Pyramid Lake. |
06-09-2008, 11:11 PM | #9 |
Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
are you sure you mean 54oz and not 5.4oz or 54g
06-10-2008, 05:57 AM | #10 | |
Rock Crawler Join Date: Apr 2007 Location: St. John's
Just drop by a auto parts store and ask for stick-on wheel weights. They usually come in a stick of 12 x 1/4 oz weights = 3.0 oz in total. The weights are easy to snap apart for fine tuning of the total weight. I think I paid less than a dollar a stick - I wouldn't even ask about the price of the Great Airplanes (?) ones at the LHS Here's a ring of 14 around a Junfac beadlock: | |
06-10-2008, 09:04 AM | #11 |
06-10-2008, 10:03 AM | #12 |
I've got to ask - "Why 54 oz?" I'm running about 12 oz on each front wheel and about 9 oz in each rear. Even at that weight my rig's axles take a bit of pounding on a rough downhill tumble!! I can't imagine what this must be like when you're running 54oz And right now I am finding my current weight working really well with my Panther's with stock foams. Just curious what advantage you see to running that much weight. |
06-10-2008, 01:04 PM | #13 |
Pebble Pounder Join Date: May 2008 Location: El Paso
i can't imagine having that much weight in my wheels! i just put some weight on my front axle and i feel like that (7.5oz) is way too much rotating mass, my stomach hurts thinking of turning the 54oz!
06-10-2008, 01:25 PM | #14 |
Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
thats 3.375 pounds in each tire or in both fronts? i only run about 9 oz in fronts and 4oz in the rear plus battery
06-10-2008, 02:38 PM | #15 |
Rock Stacker Join Date: Apr 2008 Location: Mississauga, ONT
Im running about 45oz total in the front (tires/wheels/weights/axial) and on the rear iv got about 20oz (tires/wheels/axial/batterys) I have yet to try it out because im waiting on some more parts but i beleve it should work out! |
06-10-2008, 03:34 PM | #16 |
Yeah I agree running almost 7lbs of weight in just the front axle will kill your drive line. The ring and pinions are not hardened. Plastic drive shafts and plastic gears. Even top of the line supers don't run that king of weight
06-10-2008, 06:11 PM | #17 |
That's 54 oz TOTAL weight up front but if I find it's too much, and so far so good, I can reduce it in increments of about 3.5 oz all the way down to 3.5 in each wheel. Being that the weight is close around the center of the axle the power required to turn the wheels isn't as bad as you might think. If the weight was near the outer circumference of the wheel then there might be a problem getting the thing rolling but as it stands right now I can almost pull the front wheel off the ground:-P I'll be trying it out in a comp Sat. |
06-10-2008, 10:10 PM | #18 |
Newbie Join Date: Oct 2005 Location: Fayetteville
That thing has to be crazy heavy!
06-11-2008, 06:42 PM | #19 |
Having weight is one thing and can help. 54 ounces is to much though. I forsee premature failure in the axles,lockers,shafts,gears and diffs. If you wanna run that much weight,you need to step up to big boy axles and not itty bitty 1:10 scale stuff. 2 of your tires alone are heavier than my entire 2.2 fully charged and RTR. |
06-11-2008, 09:53 PM | #20 |
Well it sure is fun watching my itty bitty AX crawling all over the rocks like like insane itty bitty bug.:-P But to each his own! |
